Problem with 2 times phase 2 Ipsec
darkmen11
Hello, I'm experiencing disconnections on my IPsec VPN, probably due to a double initiation of Phase 2. Here is an excerpt from the 'show crypto ipsec sa' command.
interface: GigabitEthernet0/0/1
Crypto map tag: VPNMAP, local addr X.X.X.X
protected vrf: (none)
local ident (addr/mask/prot/port): (X.X.X.X/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (X.X.X.X/255.255.255.0/0/0)
current_peer x.X.X.x port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: X.X.X.X, remote crypto endpt.: X.X.X.X
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/1
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
interface: Tunnel61
Crypto map tag: Tunnel61-head-0, local addr X.X.X.X
current_peer X.X.X.X port 500
PERMIT, flags={}
#pkts encaps: 1522, #pkts encrypt: 1522, #pkts digest: 1522
#pkts decaps: 1768, #pkts decrypt: 1768, #pkts verify: 1768
plaintext mtu 1438, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/1
current outbound spi: 0x6AC9659E(1791583646)
PFS (Y/N): Y, DH group: group5
inbound esp sas:
spi: 0xA65BBC56(2791029846)
transform: esp-aes esp-sha-hmac ,
in use settings ={Tunnel, }
conn id: 9297, flow_id: ESG:7297, sibling_flags FFFFFFFF80000048, crypto map: Tunnel61-head-0
sa timing: remaining key lifetime (k/sec): (4606650/3539)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 9298, flow_id: ESG:7298, sibling_flags FFFFFFFF80000048, crypto map: Tunnel61-head-0
sa timing: remaining key lifetime (k/sec): (4607879/3539)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
local crypto endpt.: X.X.X.X, remote crypto endpt.: XX.X.X.X
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
Can You please help me and tell me where is the problem ?
Thankyou
15 Replies 15
can I see the config of router or ASA ?
MHM
This is the configuration of router show running :
version 15.5
no service pad
service tcp-keepalives-in
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname XXXX_WH_SaaS_1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging buffered 512000
enable secret 5 $1$qyoK$NeNsTMb31WJail7.RDfZQ.
no aaa new-model
clock timezone UTC 1 0
clock summer-time UTC recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip source-route
subscriber templating
license udi pid ISR4331/K9 sn FXXXXXX
username snuk secret 5 $1$zd0I$yCm8pvklX5MBW3K9bl8dz1
redundancy
 mode none
vlan internal allocation policy ascending
crypto isakmp policy 1
 encr aes
 authentication pre-share
 group 5
 lifetime 1800
crypto isakmp key KFebB9D98kYT892y6xse address 1.1.1.1
crypto ipsec transform-set TS-ACSEP esp-aes esp-sha-hmac
 mode tunnel
crypto ipsec transform-set VPN-ACSEP esp-aes esp-sha-hmac
 mode tunnel
crypto ipsec profile ACSEP
 set transform-set VPN-ACSEP
 set pfs group5
crypto map VPNMAP 10 ipsec-isakmp
 set peer 1.1.1.1
 set transform-set TS-ACSEP
 match address VPN-ACSEP
interface Loopback0
 ip address 102.10.1.1 255.255.255.255
interface Tunnel61
 ip unnumbered GigabitEthernet0/0/1
 tunnel source 2.2.2.2
 tunnel mode ipsec ipv4
 tunnel destination 1.1.1.1
 tunnel protection ipsec profile ACSEP
interface GigabitEthernet0/0/0
 description ## XXXX_WH_SaaS_Core ##
 ip address 3.3.3.3 255.255.255.240
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 negotiation auto
interface GigabitEthernet0/0/1
 description ## Internet Circuit ##
 ip address 2.2.2.2 255.255.255.248
 ip nat outside
 negotiation auto
 crypto map VPNMAP
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/1/0
 description ## XXXX_WH_SaaS Interlink ##
 switchport access vlan 20
 switchport mode access
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
interface Vlan20
 ip address 102.10.10.33 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
router eigrp 102
 network 102.10.0.0 0.0.255.255
ip nat inside source route-map internet interface GigabitEthernet0/0/1 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 90.102.6.214 name Internet_Main
ip route 172.27.140.0 255.255.255.0 Tunnel61
ip access-list extended VPN-ACSEP
 permit ip 102.10.100.0 0.0.0.255 172.27.140.0 0.0.0.255
access-list 5 permit 102.10.0.0 0.0.255.255
route-map internet permit 10
 match ip address 5
route-map REDI_Static permit 10
 match tag 999
control-plane
banner motd ^CCC
                         W  A  R  N  I  N  G                        *
 Only authorised personel can access and only for official purpose. *
     Any unauthorised access will be punished by the law.           *
          All accesses and usages are being logged.                 *
^C
line con 0
 exec-timeout 5 0
 login local
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 exec-timeout 5 0
 login local
 transport input telnet
line vty 5 15
 exec-timeout 5 0
 login local
end
thank you
i think the problem is the 2nd
but i don't now how to delete it
as I thought
you config ACL of IPsec VPN
and
you config default route for same subnet toward the Tunnel
this make traffic to subnet 172.27.140.0  hit the acl and pass through tunnel.
friend since the tunnel destination is same as set peer of crypto map
then use either tunnel or policy based VPN not both
MHM
thank you for response
Indeed, I simply need to remove the ACL.?
Do I just need to do that?
no permit ip 102.10.100.0 0.0.0.255 172.27.140.0 0.0.0.255
Yes friend remove it
Clear crypto isakmp
Clear crypto sa
And then check
MHM
darkmen11
hello,
I always have the same issue. I have a request to establish IPsec 0.0.0.0 that triggers with my initial request, causing the VPN to disconnect. Below is the debug
*Jan  6 00:17:55.125 UTC: IPSEC:(SESSION ID = 118) (key_engine) request timer fired: count = 2,
  (identity) local= 1.1.1.1:0, remote= 2.2.2.2,
    local_proxy= 0.0.0.0/0.0.0.0/256/0,
    remote_proxy= 0.0.0.0/0.0.0.0/256/0
*Jan  6 00:17:55.139 UTC: IPSEC(key_engine): got a queue event with 1 KMI message(s)
*Jan  6 00:17:55.139 UTC: Delete IPsec SA by DPD, local 1.1.1.1 remote 91.151.67.34 peer port 500
*Jan  6 00:17:55.139 UTC: IPSEC:(SESSION ID = 118) (delete_sa) deleting SA,
  ug(sa) sa_dest= 1.1.1.1, sa_proto= 50,
    sa_spi= 0x940E230A(2483954442),
    sa_trans= esp-aes esp-sha-hmac , sa_conn_id= 2231
    sa_lifetime(k/sec)= (4608000/3600),
    local_proxy= 102.10.100.0/255.255.255.0/256/0,
    remote_proxy= 172.27.140.0/255.255.255.0/256/0
*Jan  6 00:17:55.139 UTC: IPSEC:(SESSION ID = 118) (delete_sa) SA found saving DEL kmi
*Jan  6 00:17:55.139 UTC: IPSEC:(SESSION ID = 118) (delete_sa) deleting SA,        sa) sa_dest= 91.151.67.34, sa_proto= 50,
    sa_spi= 0x6ACB44B8(1791706296),
    sa_trans= esp-aes esp-sha-hmac , sa_conn_id= 2232
*Jan  6 00:17:55.139 UTC: IPSEC:(SESSION ID = 118) (update_current_outbound_sa) updated peer 91.151.67.34 current outbound sa to SPI 0
*Jan  6 00:17:55.140 UTC: IPSEC:(SESSION ID = 118) (delete_sa) SA found saving DEL kmi
*Jan  6 00:17:55.140 UTC: IPSEC:(SESSION ID = 118) (delete_sa) deleting SA,
  (sa) sa_dest= 91.151.67.34, sa_proto= 50,
*Jan  6 00:17:55.140 UTC: IPSEC(sibling_delete_notify_ident_action): Ident down, not sending DECR/DELETE
*Jan  6 00:17:55.141 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel61, changed state to down
*Jan  6 00:17:55.144 UTC: IPSEC:(SESSION ID = 118) (ident_update_final_flow_stats) Collect Final Stats and update MIB
IPSEC get IKMP peer index from peer 0x7FAE88AB68D0 ikmp handle 0x80000075
IPSEC IKMP peer index 0
[ident_update_final_flow_stats] : Flow delete complete event received for flow id 0x240000E7,peer index 0
share last config
MHM
darkmen11
I restored the same initial configuration since removing 'permit ip 102.10.100.0 0.0.0.255 172.27.140.0 0.0.0.255' did not change anything. I still have a second IPsec request for the IP addresses 0.0.0.0 that occurs after my initial request. After three failed requests with the 0.0.0.0, the connection is reset."
if you have VTI and it protect this subnet why you use crypto map to protect same subnet ?
sure you will have two SA
MHM
to make it simple to you share your topology let me see why you need two IPsec (VTI and Crypto map) in your case
MHM
darkmen11
thank you for answer
I don't need 2 ipsec
How can I delete one?
Remove crypto map you add under interfac <- if you want to remove policy based vpn
Shut the tunnel interface <- if you want to remove route based VPN
You have two choices here
MHM
darkmen11
thank you for your assistance. I will test it tonight but Which configuration do you think could generate this:
local_proxy = 0.0.0.0/0.0.0.0/256/0, remote_proxy = 0.0.0.0/0.0.0.0/256/0,
crypto map, or tunnel interface?"
