Problem with cisco vpn client
luongdung
We are using cisco vpn client to connect VPN server (ASA 5510).With VPN Connection, Cisco vpn client can only connect the services in LAN other than services is published/NATed to internet via this ASA 5510. For example: On one server, vpn client can not access the services publishing to the Internet while other services not publish to the Internet on the same server remains accessible via vpn client
How can I fix this problem ?
Alex
rizwanr74
Level 7
Level 7
Hi there,
"For example: On one server, vpn client can not access the services publishing to the Internet while other services not publish to the Internet on the same server remains accessible via vpn client"
Include public address into the tunnel by the means of split-tunnel.
"while other services not publish to the Internet on the same server remains accessible via vpn client"
Your client accessing none-publish service via the private address, right ?
thanks
Rizwan Rafeek
