Problem with PPP Keepalive
zahid.hassan
Level 2
Level 2
Dear All,
We are running a Cisco 7206VXR with IOS version 12.2(15)T10 as a L2TP LNS.
Quite often our customers fail to connect and the RADIUS logs show Port-Error as the
Terminate Cause:
Acct-Terminate-Cause = Port-Error
Cisco's online documentation (and even the RFC's) were very unhelpful in
explaining this cryptic terminate cause.
Does this indicate a problem with the customer's CPE, with the
ATM network or with our router?
Anybody have any experience with this?
Zahid
tepatel
Port-Error can be because of PPP keepalives failed or not received on CPE or aggregation box like 7206.
You will see that error mostly if aggregation box missed 5 PPP keepalives from CPE. So to troubleshoot that issue, you need to see which user is having that problem and make sure that CPE used by that user is configured properly wrt to ppp keepalive.
Many thanks for the explaination.
Is there command to change the default Keepalive value on the LNS ?
I would assume this would need to done
under the virtual template config.
My virtual template config is as follows:
interface Virtual-Template1
ip unnumbered Loopback1
no ip redirects
ip mtu 1460
ip tcp adjust-mss 1420
no logging event link-status
no peer default ip address
ppp mtu adaptive
ppp authentication chap callin
ppp multilink
Zahid
keepalive 60 (in seconds)
