Problem with Site-Site PKI Ipsec VPN
CarlMason8531
Hi All,
First post, but avid viewer be kind..!
Got a strange problem which I've never encountered before with a site to site VPN between a head-end 2921 and the satellite 1941.
Site lost power and it appears the time was out when restored - having reset the time and re-enrolled the satellite site and renewing the expired certificate I'm seeing %CRYPTO-6-IKMP_NO_ID_CERT_ADDR_MATCH messages every 90 seconds or so on the satellite.
So sh cryp session brief on the headend shows the satelite as UA - the uptime lasts for about 1:30 before dropping. Satelite side shows no pkts.
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
Head end :
PERMIT, flags={origin_is_acl,}
#pkts encaps: 10, #pkts encrypt: 10, #pkts digest: 10
Logging shows a similar picture:
n 5 09:03:49.039: IPSEC(create_sa): sa created,
(sa) sa_dest= [HEADEND], sa_proto= 50,
sa_spi= 0xC20BC1B6(3255550390),
sa_trans= esp-aes esp-sha-hmac , sa_conn_id= 3695
sa_lifetime(k/sec)= (4608000/3600)
Jun 5 09:03:49.039: IPSEC(create_sa): sa created,
(sa) sa_dest= [BRANCH], sa_proto= 50,
sa_spi= 0x829B8D42(2191232322),
sa_trans= esp-aes esp-sha-hmac , sa_conn_id= 3696
Jun 5 09:03:49.039: IPSEC: Expand action denied, notify RP
Jun 5 09:03:49.043: IPSEC(rte_mgr): VPN Route Event Install new outbound sa: Create IPV4 route from ACL for [BRANCH]
Jun 5 09:03:49.043: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to up
Jun 5 09:05:18.807: ISAKMP:(0):: peer matches headend-profile profile
Jun 5 09:05:18.815: %CRYPTO-6-IKMP_NO_ID_CERT_ADDR_MATCH: ID of [BRANCH] (type 1) and certificate addr with
Jun 5 09:05:18.823: %CRYPTO-5-IKEV2_SESSION_STATUS: Crypto tunnel v2 is DOWN. Peer [BRANCH]:500 Id: [BRANCH]
Jun 5 09:05:18.823: IPSEC(key_engine): got a queue event with 1 KMI message(s)
Jun 5 09:05:18.823: IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
Jun 5 09:05:18.823: IPSEC(key_engine_delete_sas): delete SA with spi 0xC20BC1B6 proto 50 for [HEADEND]
Jun 5 09:05:18.823: IPSEC(update_current_outbound_sa): updated peer [BRANCH] current outbound sa to SPI 829B8D42
Jun 5 09:05:18.823: IPSEC(delete_sa): deleting SA,
sa_lifetime(k/sec)= (4608000/3600),
(identity) local= [HEADEND]:0, remote= [BRANCH]:0,
local_proxy= 0.0.0.0/0.0.0.0/256/0,
remote_proxy= 0.0.0.0/0.0.0.0/256/0
Jun 5 09:05:18.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
Jun 5 09:05:18.827: IPSEC(key_engine): got a queue event with 1 KMI message(s)
Jun 5 09:05:18.835: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
Any ideas/insights would be appreciated.
7 Replies 7
Did you change the FQDN of the certificate?
Do you re-enroll with the same Certificate Authority and each router has the Root Certificate?
Can you provide the output of "show crypto pki certificates verb" from both Hub and Spoke please
Also provide the full configuration if possible
Hi RJI,
Thanks for the quick reply.
I didn't change the FQDN - same hostname and yes, same CA (its other spokes are fine) and the problem router does have the same root certificate. I've just tried creating a new trustpoint and re-enrolling to no avail. The only thing I can see in the debugging is there is no inbound activity on the spoke whereas a working one does (obviously)..
Quick note on the configs - for my own sanity I've done a line by line comparison of two spoke configs (one working and this one) and they are identical less hostnames/ local ips. So it does look to be an issue relating to the pki.
cfgs/output attached
On your Hub you have 2 x IKEv2 Profiles, 1 with Certificate authentication (headend-profile) and the other with PSK (azure-profile).
I assume you should must be using the headend-profile if you are using certificates? This matches a remote identity of 80.x.x.206 - is that IP address of the spoke that isn't working?
You mentioned other spokes, with this configuration only 1 IP address 80.x.x.206 could match that profile. You'd be better using a Certificate Map and matching the remote identity on that.
Hi RJI,
Correct I'm using the headend-profile on the spoke ignore the other profile, 80.x.x.206 is the spoke that isn't working correct.
Apologies I did truncate the other spokes from the headend-profile for readability - these would also be in there in the live scenario. I'll take a look at setting up a cert map.
However this cfg has worked before though,  unsure as to why it would stop with a loss of power and forced re-enrol - I did note that after the restart of the spoke the stored nvram cert was very old - the CA cert had expired so hence I did a fresh re-enroll/authenticate. (No cfg changes on the hub since either).
The looping 90 seconds of uptime on the hub is all I can seem to get atm!
Status: A- Active, U - Up, D - Down, I - Idle, S - Standby, N - Negotiating
K - No IKE
ivrf = (none)
Peer I/F Username Group/Phase1_id Uptime Status
80.x.x.206 Vi3 80.x.x.212 00:00:01 UA
Ok, can you run the test again - provide the output of the following commands (from both spoke/hub) if/when the tunnel is up.
show crypto ikev2 sa detail
show crypto ipsec sa detail
Turn on ikev2 debugs during the period the tunnel is up and let the tunnel drop and attempt to re-negotiate, then upload the output of those debugs for review. Do the debugs on both routers please.
Hi Rji,
Attached both logs as requested, cleansed a bit for readability!
Best,
As an update, a second spoke seems to be suffering the same fate. It appears that it had the old CA Server certificate at the point it went down, a re-authenticate/enroll of the second router whilst gets the correct certificates on the router - the tunnel remains down.
