Problem with Virtual Adapter (VPN client)
n.oneill
I have been running version 4.0.3C which has been working fine for some time. I upgraded to version 4.0.4 but none of my connections would work. I have tried reinstalling various versions including the original 4.0.3C but there is still a problem with the Virtual Adapter. I am now on 4.0.3F and the log is as follows:
Cisco Systems VPN Client Version 4.0.3 (F)
Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600
1 09:26:43.621 05/18/04 Sev=Warning/3 IKE/0xA3000064
Disabling Split-DNS, VPN 3000 Concentrator Version 3.5 is not supported
2 09:26:43.841 05/18/04 Sev=Warning/2 CVPND/0xE3400014
The VPN Client could not find the adapters GUID.
3 09:26:43.841 05/18/04 Sev=Warning/3 CVPND/0xE340000D
The Client was unable to enable the Virtual Adapter because it could not set the IP configuration into the registry.
4 09:26:43.841 05/18/04 Sev=Warning/2 CM/0xE310000A
The virtual adapter failed to enable
5 09:26:43.841 05/18/04 Sev=Warning/2 IKE/0xE3000099
Failed to active IPSec SA: Unable to enable Virtual Adapter (NavigatorQM:938)
6 09:26:43.841 05/18/04 Sev=Warning/2 IKE/0xE30000A5
Unexpected SW error occurred while processing Quick Mode negotiator:(Navigator:2201)
Whne I type the "ipconfig" command I no longer see the Virtual adapter listed and If I try to repair the connection it says the TCP/IP is not running on the adapter. When I look at the adapter TCP/IP is bound. I am unable to use system restore as I have no restores from before the first upgrade. I am running Windows XP with SP 1 and all the hotfixes.
The device seems to be locked and I can't remove it from the registry.
Any help much appreciated.
ehirsel
Level 6
Level 6
You may have an issue with the DNE device. See if DNE is still bound the to adapter.
Here is some doc from the cisco vpn client faq:
A. Check the networking Control Panel to ensure that the Deterministic NDIS Extender (DNE) was not installed. Also check for the uninstall file by going to Microsoft > Current Version > Uninstall. Then remove the HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\{5624C000-B109-11D4-9DB4-00E0290FCAC5} file and retry the uninstallation.
Even better this link describes how to uninstall the vpn client v3.5 and higer under windows 2000. For XP it may be similar.
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a0080094b7f.shtml
Let me know if one of these took care of your issue.
Thanks very much for the helpful response.
I found the article on manually uninstalling the VPN client before your post which I did to no avail.
I then used the "netsh" command to reset the IP config in XP and resinatlled the client. (You cant remove IP from XP)
The client now works, however, I do not see the Virtual adapter listed in the Network Connections or if I do an ipconfig. Even more bizarre is the fact that no routing entries exist either but the VPN works ok so I will put up with it for now!
Thanks again and yes it's definitly the DNE which is the problem!
