04-08-2013 05:49 AM
I have configured a new router for a customer.
All works fine but i have a strange issue with the VPN client.
When i start the VPN the client don't close the connection, ask for password, start to negotiate security policy the show the not connected status.
This is the log form the VPN client:
Cisco Systems VPN Client Version 5.0.07.0290
Copyright (C) 1998-2010 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.1.7601 Service Pack 1
Config file directory: C:\Program Files (x86)\Cisco Systems\VPN Client\
1 14:37:59.133 04/08/13 Sev=Info/6 GUI/0x63B00011
Reloaded the Certificates in all Certificate Stores successfully.
2 14:38:01.321 04/08/13 Sev=Info/4 CM/0x63100002
Begin connection process
3 14:38:01.335 04/08/13 Sev=Info/4 CM/0x63100004
Establish secure connection
4 14:38:01.335 04/08/13 Sev=Info/4 CM/0x63100024
Attempt connection with server "asgardvpn.dyndns.info"
5 14:38:02.380 04/08/13 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 79.52.36.120.
6 14:38:02.384 04/08/13 Sev=Info/4 IKE/0x63000001
Starting IKE Phase 1 Negotiation
7 14:38:02.388 04/08/13 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 79.52.36.120
8 14:38:02.396 04/08/13 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
9 14:38:02.396 04/08/13 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
10 14:38:02.460 04/08/13 Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 79.52.36.120
11 14:38:02.460 04/08/13 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, VID(Unity), VID(dpd), VID(?), VID(Xauth), VID(Nat-T), KE, ID, NON, HASH, NAT-D, NAT-D) from 79.52.36.120
12 14:38:02.506 04/08/13 Sev=Info/6 GUI/0x63B00012
Authentication request attributes is 6h.
13 14:38:02.460 04/08/13 Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
14 14:38:02.460 04/08/13 Sev=Info/5 IKE/0x63000001
Peer supports DPD
15 14:38:02.460 04/08/13 Sev=Info/5 IKE/0x63000001
Peer supports DWR Code and DWR Text
16 14:38:02.460 04/08/13 Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
17 14:38:02.460 04/08/13 Sev=Info/5 IKE/0x63000001
Peer supports NAT-T
18 14:38:02.465 04/08/13 Sev=Info/6 IKE/0x63000001
IOS Vendor ID Contruction successful
19 14:38:02.465 04/08/13 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to 79.52.36.120
20 14:38:02.465 04/08/13 Sev=Info/6 IKE/0x63000055
Sent a keepalive on the IPSec SA
21 14:38:02.465 04/08/13 Sev=Info/4 IKE/0x63000083
IKE Port in use - Local Port = 0xCEFD, Remote Port = 0x1194
22 14:38:02.465 04/08/13 Sev=Info/5 IKE/0x63000072
Automatic NAT Detection Status:
Remote end is NOT behind a NAT device
This end IS behind a NAT device
23 14:38:02.465 04/08/13 Sev=Info/4 CM/0x6310000E
Established Phase 1 SA. 1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
24 14:38:02.502 04/08/13 Sev=Info/5 IKE/0x6300002F
25 14:38:02.502 04/08/13 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 79.52.36.120
26 14:38:02.502 04/08/13 Sev=Info/4 CM/0x63100015
Launch xAuth application
27 14:38:07.623 04/08/13 Sev=Info/4 CM/0x63100017
xAuth application returned
28 14:38:07.623 04/08/13 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 79.52.36.120
29 14:38:12.656 04/08/13 Sev=Info/6 IKE/0x63000055
30 14:38:22.808 04/08/13 Sev=Info/6 IKE/0x63000055
31 14:38:32.949 04/08/13 Sev=Info/6 IKE/0x63000055
32 14:38:43.089 04/08/13 Sev=Info/6 IKE/0x63000055
33 14:38:53.230 04/08/13 Sev=Info/6 IKE/0x63000055
34 14:39:03.371 04/08/13 Sev=Info/6 IKE/0x63000055
35 14:39:13.514 04/08/13 Sev=Info/6 IKE/0x63000055
36 14:39:23.652 04/08/13 Sev=Info/6 IKE/0x63000055
37 14:39:33.807 04/08/13 Sev=Info/6 IKE/0x63000055
38 14:39:43.948 04/08/13 Sev=Info/6 IKE/0x63000055
39 14:39:54.088 04/08/13 Sev=Info/6 IKE/0x63000055
40 14:40:04.233 04/08/13 Sev=Info/6 IKE/0x63000055
41 14:40:14.384 04/08/13 Sev=Info/6 IKE/0x63000055
42 14:40:24.510 04/08/13 Sev=Info/6 IKE/0x63000055
43 14:40:34.666 04/08/13 Sev=Info/6 IKE/0x63000055
44 14:40:44.807 04/08/13 Sev=Info/6 IKE/0x63000055
45 14:40:54.947 04/08/13 Sev=Info/6 IKE/0x63000055
46 14:41:05.090 04/08/13 Sev=Info/6 IKE/0x63000055
47 14:41:15.230 04/08/13 Sev=Info/6 IKE/0x63000055
48 14:41:25.370 04/08/13 Sev=Info/6 IKE/0x63000055
49 14:41:35.524 04/08/13 Sev=Info/6 IKE/0x63000055
50 14:41:45.665 04/08/13 Sev=Info/6 IKE/0x63000055
51 14:41:55.805 04/08/13 Sev=Info/6 IKE/0x63000055
52 14:42:05.951 04/08/13 Sev=Info/6 IKE/0x63000055
53 14:42:16.089 04/08/13 Sev=Info/6 IKE/0x63000055
54 14:42:26.228 04/08/13 Sev=Info/6 IKE/0x63000055
55 14:42:36.383 04/08/13 Sev=Info/6 IKE/0x63000055
56 14:42:46.523 04/08/13 Sev=Info/6 IKE/0x63000055
57 14:42:56.664 04/08/13 Sev=Info/6 IKE/0x63000055
58 14:43:02.748 04/08/13 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=2B1FFC3754E3B290 R_Cookie=73D546631A33B5D6) reason = DEL_REASON_CANNOT_AUTH
59 14:43:02.748 04/08/13 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DWR) to 79.52.36.120
60 14:43:03.248 04/08/13 Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=2B1FFC3754E3B290 R_Cookie=73D546631A33B5D6) reason = DEL_REASON_CANNOT_AUTH
61 14:43:03.248 04/08/13 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "asgardvpn.dyndns.info" because of "DEL_REASON_CANNOT_AUTH"
62 14:43:03.248 04/08/13 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
63 14:43:03.262 04/08/13 Sev=Info/6 CM/0x63100046
Set tunnel established flag in registry to 0.
64 14:43:03.262 04/08/13 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
65 14:43:03.265 04/08/13 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
66 14:43:03.265 04/08/13 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
67 14:43:03.265 04/08/13 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
68 14:43:03.265 04/08/13 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
And this is the conf from the 1801:
hostname xxx
boot-start-marker
boot-end-marker
enable secret 5 xxx
aaa new-model
aaa authentication login xauthlist local
aaa authorization network groupauthor local
aaa session-id common
dot11 syslog
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.1.1 10.0.1.10
ip dhcp excluded-address 10.0.1.60 10.0.1.200
ip dhcp excluded-address 10.0.1.225
ip dhcp excluded-address 10.0.1.250
ip dhcp pool LAN
network 10.0.1.0 255.255.255.0
default-router 10.0.1.10
dns-server 10.0.1.200 8.8.8.8
domain-name xxx
lease infinite
ip name-server 10.0.1.200
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip inspect log drop-pkt
ip inspect name Firewall cuseeme
ip inspect name Firewall dns
ip inspect name Firewall ftp
ip inspect name Firewall h323
ip inspect name Firewall icmp
ip inspect name Firewall imap
ip inspect name Firewall pop3
ip inspect name Firewall rcmd
ip inspect name Firewall realaudio
ip inspect name Firewall rtsp
ip inspect name Firewall esmtp
ip inspect name Firewall sqlnet
ip inspect name Firewall streamworks
ip inspect name Firewall tftp
ip inspect name Firewall vdolive
ip inspect name Firewall udp
ip inspect name Firewall tcp
ip inspect name Firewall https
username xxx password 0 xxxx
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group xxx
key xxx
dns 10.0.1.200
wins 10.0.1.200
domain xxx
pool ippool
acl 101
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto ipsec transform-set xauthtransform esp-des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
archive
log config
hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode adsl2+
hold-queue 224 in
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.0.1.10 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp pap sent-username aliceadsl password 0 aliceadsl
ip local pool ippool 10.16.20.1 10.16.20.200
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 10.0.1.2
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static udp 10.0.1.60 1056 interface Dialer0 1056
ip nat inside source static tcp 10.0.1.60 1056 interface Dialer0 1056
ip nat inside source static tcp 10.0.1.60 3111 interface Dialer0 3111
ip nat inside source static udp 10.0.1.60 3111 interface Dialer0 3111
ip nat inside source list 101 interface Dialer0 overload
access-list 101 remark *** ACL nonat ***
access-list 101 deny ip 10.0.1.0 0.0.0.255 10.16.20.0 0.0.0.255
access-list 101 permit ip 10.0.1.0 0.0.0.255 any
access-list 150 remark *** ACL split tunnel ***
access-list 150 permit ip 10.0.1.0 0.0.0.255 10.16.20.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password xxx
scheduler max-task-time 5000
end
Anyone can help me ?
Sometimes the vpn can be vreated using the iPhone or iPad vpn client...
