Problem with vpn concentrator
sudeesh79
This is my current scenario
Machine1->Router1->(Intranet)->Router2->(public int) Vpn concentr(private int)-->Machine2
I am able to telnet to the public int of vpn conctr
from Machine1,but I am not able to access the vpn
conctr through the browser.Please heip me to
solve this problem
Thankx
Sud
sachin_mon
Hello Sudeesh…
For VPN 3000 conc. Release 4.1 & later
1.Select configuration>interfaces>etherner2 (public),then choose the WebVPN tab.
2.Check the Allow Management HTTPS sessions.
3.Check the Redirect HTTP to HTTPS for enhanced security.
Click Apply button & save.
Note:This checkbox setting overrides the rules defined in the Public filter (or whatever filter applied to the Public interface).You do not need to add rules to filters in WebVPN supported code.
https:///admin.html
Rules:
Click Add & then
1.Rule name:create a unique name for this rule
(for example:"Public HTTP In")
2.Action:Forward
3.Protocol:Tcp
4.Source IP:IP address of the workstation that from which you are managing.
5.Wildcard mask : 0.0.0.0
6.Destination IP: Public IP address of concenc.
7.Wildcard mask: 0.0.0.0
8.TCP/UDP Destination Port: HTTP
Click Add & Save.
Hope this helps.
Rgds.,
SM
sachin_mon
Hello Sudeesh…
https:///admin.html
Rules:
Click Add & then
2.Action:Forward
3.Protocol:Tcp
Click Add & Save.
Hope this helps.
Rgds.,
SM
