09-08-2013 11:08 PM
Hello All,
I am experiencing issues configuring WebVPN on a cisco 871W. Would someone be able to point out the problems in my configuration?
aaa new-model
aaa authentication login sslvpn local
ip domain name LAKEVIEW
crypto pki trustpoint my-trustpoint
enrollment selfsigned
serial-number
subject-name CN=firewallcx-certificate
revocation-check crl
rsakeypair my-rsa-keys
webvpn gateway MY-CISCO-WEBVPN-GATEWAY
ip address 192.168.0.1 port 443
ssl encryption aes-sha1
ssl trustpoint my-trustpoint
inservice
webvpn install svc usbflash0:/webvpn/svc.pkg
webvpn context Cisco-WebVPN
title "Tyson's home VPN"
ssl authenticate verify all
login-message "Cisco Secure Login WebVPN"
policy group WEBVPNPOLICY
functions svc-enabled
svc address-pool "webvpn-pool"
svc rekey method new-tunnel
svc split include 192.168.0.0 255.255.255.0
default-group-policy WEBVPNPOLICY
aaa authentication list sslvpn
gateway MY-CISCO-WEBVPN-GATEWAY domain webvpn
inservice webvpn gateway MY-CISCO-WEBVPN-GATEWAY
ip address 50.174.58.233 port 443
inservice
09-10-2013 06:27 AM
1. You have to enable SSL on this router.
Check it.
ip http secure-server
2. I have verified your configuration. You have entered the two defined webvpn gateways with the same name?
In my opinion, correct configuration should look like this:
serial-number
inservice
domain webvpn
inservice
Try it out.
3. Put the results of the commands:
show webvpn gateway
show webvpn install status svc
show webvpn context
________________
Best regards,
MB
09-10-2013 02:06 PM
Hey MB thanks for the reply!
When I get home I will try this in about 8 hours.
I was also wondering if you know where I can find documentation to implement this feature. I have actually just been scrouging through various internet sites to find information, but I really don't have a solid idea what all the commands are actually doing.
For example, I am really blurry about what the following commands are accomplishing:
serial-number
subject-name CN=firewallcx-certificate = = = > What is this line doing?
09-11-2013 03:38 AM
Hello
Interesting article (you have read it already )
D'Juan Tyson napisano:
For example, I am really blurry about what the following commands are accomplishing:crypto pki trustpoint my-trustpoint
serial-number
The subject-name subcommand allows you to specify other options in the certificate.
For example, you can sets the fields:
C= (Country)
CA= (Certificate authority)
CN= (Common Name)
O= (Organization)
OU= (Organizational Unit)
ST= (State)
If the subject-name subcommand is not used, by default, the router Fully Qualified Domain Name (FQDN) is used.
For example:
ip hostname webvpn
ip domain-name company.com
the FQDN in the certificate will be: webvpn.company.com
P.S.
If https is already running on the router - it means that the self-signed certificate is created, because the router generates it automatically.
Or you can generate it now (enter the command: ip http secure-server)
You can use this certificate, read below article:
http://tekcert.com/blog/2011/08/05/configuring-clientless-ssl-vpn-webvpn-cisco-ios-routers
At section: "A key point to make here is that enabling http secure-server (https) forces the router to create a self-signed certificate if it hasn't already done so."
________________
Best regards,
MB
09-11-2013 11:47 PM
Hey MB,
The output you request is below:
My871W#show webvpn context
Codes: AS - Admin Status, OS - Operation Status
VHost - Virtual Host
Context Name Gateway Domain/VHost VRF AS OS
Cisco-WebVPN MY-CISCO webvpn - up up
My871W#show webvpn install status svc
SSLVPN Package SSL-VPN-Client version installed:
CISCO STC win2k+
3,1,03103
Hostscan Version 3.1.03103
Tue 03/26/2013 8:55:10.17 J
My871W#show webvpn gateway
Gateway Name Admin Operation
MY-CISCO-WEBVPN-GATEWAY up up
09-12-2013 02:11 AM
The results - here everything looks fine.
To verify if the certificate is correctly installed on the router, paste the output:
sh crypto pki certificates
So what is the issue?
Please explain it or provide more information.
09-12-2013 08:47 PM
Hey MB,
My certifcate output is below. I really appreciate you helping me with this becuase I have no idea where to luck. It seems that I followed all the commands correctly but when I try to connect to the firewall using my iphone app "anyconnect" , I cannot form a VPN connection. Maybe you have some more troubleshooting steps I can perform. Were you able to get this working on your 871W?
My871W#sh crypto pki certificates
Router Self-Signed Certificate
Status: Available
Certificate Serial Number: 02
Certificate Usage: General Purpose
Issuer:
serialNumber=FHK100850LZ+hostname=My871W.LAKEVIEW
cn=firewallcx-certificate
Subject:
Serial Number: FHK100850LZ
Validity Date:
start date: 04:34:42 UTC Nov 5 2002
end date: 00:00:00 UTC Jan 1 2020
Associated Trustpoints: my-trustpoint
Storage: nvram:FHK100850LZh#5702.cer
09-13-2013 03:49 AM
Specify your IOS version.
Cisco IOS recommendation: "An advanced image of Cisco IOS Software Release 12.4(6)T or later"
Troubleshooting:
1. Check the SSL VPN clientless mode
Open the web portal: "https://IP_of_your_WebVPN_gateway" and verify that you can log.
2. SSL VPN Debug Commands
Here is available one command with many options.
We'll use it without options:
- enable debugging
debug webvpn
- do try connect from AnyConnect and collect the logs
- turn off debugging
no debug all
Do analize the logs or paste here
________________
Best regards,
MB
Please rate all helpful posts
09-12-2013 08:53 PM
MB,
When I try to connect to the VPN the anyconnect app says that it cannot verify the certificate?
DT
09-13-2013 02:00 AM
Hey DT,
I'm not sure if this is the problem.
Not enough information. Maybe this?
"Untrusted VPN Server Certificate!, AnyConnect cannot verify the VPN server: ........"
Server Certificates
A valid, trusted server certificate configured on the secure gateway provides an easy and safe VPN connection for the user.
AnyConnect on mobile devices provides improved security protection when accessing a secure gateway by blocking the VPN connection if the certificate presented by the secure gateway is invalid or untrusted, or both.
A new Block Untrusted Servers application setting determines how AnyConnect blocks connections if it cannot identify the secure gateway. This protection is ON by default; it can be turned OFF by the user, but this is not recommended.
AnyConnect uses the digital certificate received from the server to verify its identify. If the certificate is invalid (there is a certificate error due to an expired or invalid date, wrong key usage, or a name mismatch), or if it is untrusted (the certificate cannot be verified by a Certificate Authority), or both, the connection is blocked. A blocking message displays, and the user must choose how to proceed.
When Block Untrusted Servers is ON, a blocking Untrusted VPN Server notification alerts the user to this security threat. The user can choose:
•Keep Me Safe to terminate this connection and remain safe.
•Change Settings to turn the Block Untrusted Servers application preference OFF, but this is not recommended. After the user disables this security protection, they must reinitiate the VPN connection.
When Block Untrusted Servers is OFF, a nonblocking Untrusted VPN Server notification alerts the user to this security threat. The user can choose to:
•Cancel the connection and remain safe.
•Continue the connection, but this is not recommended.
View Details of the certificate.
If the certificate that the user is viewing is valid but untrusted, the user can:
Import the server certificate into the AnyConnect certificate store for future use and continue the connection by selecting Import and Continue. Once this certificate is imported into the AnyConnect store, subsequent connections made to the server using this digital certificate are automatically accepted.
Go back to the previous screen and choose Cancel or Continue.
If the certificate is invalid, for any reason, the user can only return to the previous screen and choose Cancel or Continue.
Leaving the Block Untrusted Servers setting ON, having a valid, trusted server certificate configured on your secure gateway, and instructing your mobile users to always choose Keep Me Safe is the safest configuration for VPN connectivity to your network.
Try it, and reply.
Please, enter the full error message or attach example (screen) from the Internet.
________________
Best regards,
MB
