Remote Access VPN Problem with ASA 5505
matt020191
After about ~1 year of having the Cisco VPN Client connecting to a ASA 5505 without any problems, suddenly one day it stops working. The client is able to get a connection to the ASA and browse the local network for only about 30 seconds after connection. After that, no access is available to the network behind the ASA. I tried everything that I can think of to try and troubleshoot the problem, but at this point I am just banging my head against a wall. Does anyone know what could cause this?
Here is the running cfg of the ASA
: Saved
ASA Version 8.4(1)
hostname NCHCO
enable password xxxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxx encrypted
names
name 192.168.2.0 NCHCO description City Offices
name 192.168.2.80 VPN_End
name 192.168.2.70 VPN_Start
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address **.**.***.*** 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
speed 100
duplex full
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa841-k8.bin
ftp mode passive
object network NCHCO
subnet 192.168.2.0 255.255.255.0
object network obj-192.168.1.0
subnet 192.168.1.0 255.255.255.0
object network obj-192.168.2.64
subnet 192.168.2.64 255.255.255.224
object network obj-0.0.0.0
subnet 0.0.0.0 255.255.255.0
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Webserver
object network FINX
host 192.168.2.11
object service rdp
service tcp source range 1 65535 destination eq 3389
description rdp
access-list outside_nat0_outbound extended permit ip object NCHCO 192.168.1.0 255.255.255.0
access-list outside_nat0_outbound extended permit ip object NCHCO 192.168.2.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip object NCHCO 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 192.168.2.64 255.255.255.224
access-list inside_nat0_outbound extended permit ip 0.0.0.0 255.255.255.0 192.168.2.64 255.255.255.224
access-list outside_1_cryptomap extended permit ip object NCHCO 192.168.1.0 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip object NCHCO 192.168.1.0 255.255.255.0
access-list LAN_Access standard permit 192.168.2.0 255.255.255.0
access-list LAN_Access standard permit 0.0.0.0 255.255.255.0
access-list NCHCO_splitTunnelAcl_1 standard permit 192.168.2.0 255.255.255.0
access-list AnyConnect_Client_Local_Print extended deny ip any any
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq lpd
access-list AnyConnect_Client_Local_Print remark IPP: Internet Printing Protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 631
access-list AnyConnect_Client_Local_Print remark Windows' printing port
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 9100
access-list AnyConnect_Client_Local_Print remark mDNS: multicast DNS protocol
access-list AnyConnect_Client_Local_Print extended permit udp any host 224.0.0.251 eq 5353
access-list AnyConnect_Client_Local_Print remark LLMNR: Link Local Multicast Name Resolution protocol
access-list AnyConnect_Client_Local_Print extended permit udp any host 224.0.0.252 eq 5355
access-list AnyConnect_Client_Local_Print remark TCP/NetBIOS protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 137
access-list AnyConnect_Client_Local_Print extended permit udp any any eq netbios-ns
access-list outside_access_in extended permit tcp any object FINX eq 3389
access-list outside_access_in_1 extended permit object rdp any object FINX
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPN_Pool VPN_Start-VPN_End mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649.bin
no asdm history enable
arp timeout 14400
nat (inside,any) source static NCHCO NCHCO destination static obj-192.168.1.0 obj-192.168.1.0
nat (inside,any) source static any any destination static obj-192.168.2.64 obj-192.168.2.64
nat (inside,any) source static obj-0.0.0.0 obj-0.0.0.0 destination static obj-192.168.2.64 obj-192.168.2.64
nat (inside,outside) dynamic interface
object network FINX
nat (inside,outside) static interface service tcp 3389 3389
access-group outside_access_in_1 in interface outside
route outside 0.0.0.0 0.0.0.0 69.61.228.177 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
network-acl outside_nat0_outbound
webvpn
  svc ask enable default svc
http server enable
http 192.168.1.0 255.255.255.0 inside
http **.**.***.*** 255.255.255.255 outside
http NCHCO 255.255.255.0 inside
http 96.11.251.186 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set l2tp-transform esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set l2tp-transform mode transport
crypto ipsec ikev1 transform-set vpn-transform esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_SHA mode transport
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set TRANS_ESP_3DES_MD5 mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map dyn-map 10 set pfs group1
crypto dynamic-map dyn-map 10 set ikev1 transform-set l2tp-transform vpn-transform
crypto dynamic-map dyn-map 10 set reverse-route
crypto dynamic-map outside_dyn_map 20 set ikev1 transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 20 set reverse-route
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 74.219.208.50
crypto map outside_map 1 set ikev1 transform-set ESP-3DES-SHA
crypto map outside_map 20 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto map vpn-map 1 match address outside_1_cryptomap_1
crypto map vpn-map 1 set pfs group1
crypto map vpn-map 1 set peer 74.219.208.50
crypto map vpn-map 1 set ikev1 transform-set ESP-3DES-SHA
crypto map vpn-map 10 ipsec-isakmp dynamic dyn-map
crypto isakmp identity address
crypto ikev1 enable inside
crypto ikev1 enable outside
crypto ikev1 ipsec-over-tcp port 10000
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto ikev1 policy 15
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 35
encryption 3des
hash sha
group 2
lifetime 86400
client-update enable
telnet 192.168.1.0 255.255.255.0 inside
telnet NCHCO 255.255.255.0 inside
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh NCHCO 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 192.168.2.150-192.168.2.225 inside
dhcpd dns 216.68.4.10 216.68.5.10 interface inside
dhcpd lease 64000 interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 192.168.2.1
vpn-tunnel-protocol ikev1 l2tp-ipsec
default-domain value nchco.local
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-client ssl-clientless
password-storage enable
ipsec-udp enable
intercept-dhcp 255.255.255.0 enable
address-pools value VPN_Pool
group-policy NCHCO internal
group-policy NCHCO attributes
dns-server value 192.168.2.1 8.8.8.8
split-tunnel-policy tunnelspecified
split-tunnel-network-list value NCHCO_splitTunnelAcl_1
default-domain value NCHCO.local
username admin password LbMiJuAJjDaFb2uw encrypted privilege 15
username 8njferg password yB1lHEVmHZGj5C2Z encrypted privilege 15
username NCHvpn99 password dhn.JzttvRmMbHsP encrypted
tunnel-group DefaultRAGroup general-attributes
address-pool (inside) VPN_Pool
address-pool VPN_Pool
authentication-server-group (inside) LOCAL
authentication-server-group (outside) LOCAL
authorization-server-group LOCAL
authorization-server-group (inside) LOCAL
authorization-server-group (outside) LOCAL
default-group-policy DefaultRAGroup
strip-realm
strip-group
tunnel-group DefaultRAGroup ipsec-attributes
ikev1 pre-shared-key *****
peer-id-validate nocheck
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
no authentication ms-chap-v1
authentication ms-chap-v2
tunnel-group DefaultWEBVPNGroup ppp-attributes
authentication pap
tunnel-group 74.219.208.50 type ipsec-l2l
tunnel-group 74.219.208.50 ipsec-attributes
tunnel-group NCHCO type remote-access
tunnel-group NCHCO general-attributes
default-group-policy NCHCO
tunnel-group NCHCO ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:a2110206e1af06974c858fb40c6de2fc
: end
asdm location VPN_Start 255.255.255.255 inside
asdm location VPN_End 255.255.255.255 inside
And here is the logs from the Cisco VPN Client when it browses, then fails to browse the network behind the ASA:
Cisco Systems VPN Client Version 5.0.07.0440
Copyright (C) 1998-2010 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.1.7601 Service Pack 1
Config file directory: C:\Program Files (x86)\Cisco Systems\VPN Client\
1      09:44:55.677  10/01/13  Sev=Info/6    CERT/0x63600026
Attempting to find a Certificate using Serial Hash.
2      09:44:55.677  10/01/13  Sev=Info/6    CERT/0x63600027
Found a Certificate using Serial Hash.
3      09:44:55.693  10/01/13  Sev=Info/6    GUI/0x63B00011
Reloaded the Certificates in all Certificate Stores successfully.
4      09:45:02.802  10/01/13  Sev=Info/4    CM/0x63100002
Begin connection process
5      09:45:02.802  10/01/13  Sev=Info/4    CM/0x63100004
Establish secure connection
6      09:45:02.802  10/01/13  Sev=Info/4    CM/0x63100024
Attempt connection with server "**.**.***.***"
7      09:45:02.802  10/01/13  Sev=Info/6    IKE/0x6300003B
Attempting to establish a connection with **.**.***.***.
8      09:45:02.818  10/01/13  Sev=Info/4    IKE/0x63000001
Starting IKE Phase 1 Negotiation
9      09:45:02.865  10/01/13  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to **.**.***.***
10     09:45:02.896  10/01/13  Sev=Info/5    IKE/0x6300002F
Received ISAKMP packet: peer = **.**.***.***
11     09:45:02.896  10/01/13  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?)) from **.**.***.***
12     09:45:02.896  10/01/13  Sev=Info/5    IKE/0x63000001
Peer is a Cisco-Unity compliant peer
13     09:45:02.896  10/01/13  Sev=Info/5    IKE/0x63000001
Peer supports XAUTH
14     09:45:02.896  10/01/13  Sev=Info/5    IKE/0x63000001
Peer supports DPD
15     09:45:02.896  10/01/13  Sev=Info/5    IKE/0x63000001
Peer supports NAT-T
16     09:45:02.896  10/01/13  Sev=Info/5    IKE/0x63000001
Peer supports IKE fragmentation payloads
17     09:45:02.927  10/01/13  Sev=Info/6    IKE/0x63000001
IOS Vendor ID Contruction successful
18     09:45:02.927  10/01/13  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to **.**.***.***
19     09:45:02.927  10/01/13  Sev=Info/4    IKE/0x63000083
IKE Port in use - Local Port =  0xDD3B, Remote Port = 0x01F4
20     09:45:02.927  10/01/13  Sev=Info/5    IKE/0x63000072
Automatic NAT Detection Status:
   Remote end is NOT behind a NAT device
   This   end is NOT behind a NAT device
21     09:45:02.927  10/01/13  Sev=Info/4    CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
22     09:45:02.943  10/01/13  Sev=Info/5    IKE/0x6300002F
23     09:45:02.943  10/01/13  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from **.**.***.***
24     09:45:02.943  10/01/13  Sev=Info/4    CM/0x63100015
Launch xAuth application
25     09:45:03.037  10/01/13  Sev=Info/6    GUI/0x63B00012
Authentication request attributes is 6h.
26     09:45:03.037  10/01/13  Sev=Info/4    CM/0x63100017
xAuth application returned
27     09:45:03.037  10/01/13  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to **.**.***.***
28     09:45:03.037  10/01/13  Sev=Info/4    IPSEC/0x63700008
IPSec driver successfully started
29     09:45:03.037  10/01/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
30     09:45:03.083  10/01/13  Sev=Info/5    IKE/0x6300002F
31     09:45:03.083  10/01/13  Sev=Info/4    IKE/0x63000014
32     09:45:03.083  10/01/13  Sev=Info/4    IKE/0x63000013
33     09:45:03.083  10/01/13  Sev=Info/4    CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
34     09:45:03.083  10/01/13  Sev=Info/5    IKE/0x6300005E
Client sending a firewall request to concentrator
35     09:45:03.083  10/01/13  Sev=Info/4    IKE/0x63000013
36     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300002F
37     09:45:03.146  10/01/13  Sev=Info/4    IKE/0x63000014
38     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_ADDRESS: , value = 192.168.2.70
39     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_NETMASK: , value = 255.255.255.0
40     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(1): , value = 192.168.2.1
41     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(2): , value = 8.8.8.8
42     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SAVEPWD: , value = 0x00000001
43     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SPLIT_INCLUDE (# of split_nets), value = 0x00000001
44     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300000F
SPLIT_NET #1
    subnet = 192.168.2.0
    mask = 255.255.255.0
    protocol = 0
    src port = 0
    dest port=0
45     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_DEFDOMAIN: , value = NCHCO.local
46     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_UDP_NAT_PORT, value = 0x00002710
47     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_PFS: , value = 0x00000000
48     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300000E
MODE_CFG_REPLY: Attribute = APPLICATION_VERSION, value = Cisco Systems, Inc ASA5505 Version 8.4(1) built by builders on Mon 31-Jan-11 02:11
49     09:45:03.146  10/01/13  Sev=Info/5    IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SMARTCARD_REMOVAL_DISCONNECT: , value = 0x00000001
50     09:45:03.146  10/01/13  Sev=Info/4    CM/0x63100019
Mode Config data received
51     09:45:03.146  10/01/13  Sev=Info/4    IKE/0x63000056
Received a key request from Driver: Local IP = 192.168.2.70, GW IP = **.**.***.***, Remote IP = 0.0.0.0
52     09:45:03.146  10/01/13  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to **.**.***.***
53     09:45:03.177  10/01/13  Sev=Info/5    IKE/0x6300002F
54     09:45:03.177  10/01/13  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:STATUS_RESP_LIFETIME) from **.**.***.***
55     09:45:03.177  10/01/13  Sev=Info/5    IKE/0x63000045
RESPONDER-LIFETIME notify has value of 86400 seconds
56     09:45:03.177  10/01/13  Sev=Info/5    IKE/0x63000047
This SA has already been alive for 1 seconds, setting expiry to 86399 seconds from now
57     09:45:03.193  10/01/13  Sev=Info/5    IKE/0x6300002F
58     09:45:03.193  10/01/13  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK QM *(HASH, SA, NON, ID, ID, NOTIFY:STATUS_RESP_LIFETIME) from **.**.***.***
59     09:45:03.193  10/01/13  Sev=Info/5    IKE/0x63000045
RESPONDER-LIFETIME notify has value of 28800 seconds
60     09:45:03.193  10/01/13  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH) to **.**.***.***
61     09:45:03.193  10/01/13  Sev=Info/5    IKE/0x63000059
Loading IPsec SA (MsgID=967A3C93 OUTBOUND SPI = 0xAAAF4C1C INBOUND SPI = 0x3EBEBFC5)
62     09:45:03.193  10/01/13  Sev=Info/5    IKE/0x63000025
Loaded OUTBOUND ESP SPI: 0xAAAF4C1C
63     09:45:03.193  10/01/13  Sev=Info/5    IKE/0x63000026
Loaded INBOUND ESP SPI: 0x3EBEBFC5
64     09:45:03.193  10/01/13  Sev=Info/5    CVPND/0x63400013
    Destination           Netmask           Gateway         Interface   Metric
        0.0.0.0           0.0.0.0       96.11.251.1     96.11.251.149      261
    96.11.251.0     255.255.255.0     96.11.251.149     96.11.251.149      261
  96.11.251.149   255.255.255.255     96.11.251.149     96.11.251.149      261
  96.11.251.255   255.255.255.255     96.11.251.149     96.11.251.149      261
      127.0.0.0         255.0.0.0         127.0.0.1         127.0.0.1      306
      127.0.0.1   255.255.255.255         127.0.0.1         127.0.0.1      306
127.255.255.255   255.255.255.255         127.0.0.1         127.0.0.1      306
    192.168.1.0     255.255.255.0       192.168.1.3       192.168.1.3      261
    192.168.1.3   255.255.255.255       192.168.1.3       192.168.1.3      261
  192.168.1.255   255.255.255.255       192.168.1.3       192.168.1.3      261
      224.0.0.0         240.0.0.0         127.0.0.1         127.0.0.1      306
      224.0.0.0         240.0.0.0     96.11.251.149     96.11.251.149      261
      224.0.0.0         240.0.0.0       192.168.1.3       192.168.1.3      261
255.255.255.255   255.255.255.255         127.0.0.1         127.0.0.1      306
255.255.255.255   255.255.255.255     96.11.251.149     96.11.251.149      261
255.255.255.255   255.255.255.255       192.168.1.3       192.168.1.3      261
65     09:45:03.521  10/01/13  Sev=Info/6    CVPND/0x63400001
Launch VAInst64 to control IPSec Virtual Adapter
66     09:45:03.896  10/01/13  Sev=Info/4    CM/0x63100034
The Virtual Adapter was enabled:
    IP=192.168.2.70/255.255.255.0
    DNS=192.168.2.1,8.8.8.8
    WINS=0.0.0.0,0.0.0.0
    Domain=NCHCO.local
    Split DNS Names=
67     09:45:03.912  10/01/13  Sev=Info/5    CVPND/0x63400013
      224.0.0.0         240.0.0.0           0.0.0.0           0.0.0.0      261
255.255.255.255   255.255.255.255           0.0.0.0           0.0.0.0      261
68     09:45:07.912  10/01/13  Sev=Info/4    CM/0x63100038
Successfully saved route changes to file.
69     09:45:07.912  10/01/13  Sev=Info/5    CVPND/0x63400013
  **.**.***.***   255.255.255.255       96.11.251.1     96.11.251.149      100
    192.168.2.0     255.255.255.0      192.168.2.70      192.168.2.70      261
    192.168.2.0     255.255.255.0       192.168.2.1      192.168.2.70      100
   192.168.2.70   255.255.255.255      192.168.2.70      192.168.2.70      261
  192.168.2.255   255.255.255.255      192.168.2.70      192.168.2.70      261
      224.0.0.0         240.0.0.0      192.168.2.70      192.168.2.70      261
255.255.255.255   255.255.255.255      192.168.2.70      192.168.2.70      261
70     09:45:07.912  10/01/13  Sev=Info/6    CM/0x63100036
The routing table was updated for the Virtual Adapter
71     09:45:07.912  10/01/13  Sev=Info/4    CM/0x6310001A
One secure connection established
72     09:45:07.943  10/01/13  Sev=Info/4    CM/0x6310003B
Address watch added for 96.11.251.149.  Current hostname: psaserver, Current address(es): 192.168.2.70, 96.11.251.149, 192.168.1.3.
73     09:45:07.943  10/01/13  Sev=Info/4    CM/0x6310003B
Address watch added for 192.168.2.70.  Current hostname: psaserver, Current address(es): 192.168.2.70, 96.11.251.149, 192.168.1.3.
74     09:45:07.943  10/01/13  Sev=Info/5    CM/0x63100001
Did not find the Smartcard to watch for removal
75     09:45:07.943  10/01/13  Sev=Info/4    IPSEC/0x63700014
Deleted all keys
76     09:45:07.943  10/01/13  Sev=Info/4    IPSEC/0x63700010
Created a new key structure
77     09:45:07.943  10/01/13  Sev=Info/4    IPSEC/0x6370000F
Added key with SPI=0x1c4cafaa into key list
78     09:45:07.943  10/01/13  Sev=Info/4    IPSEC/0x63700010
79     09:45:07.943  10/01/13  Sev=Info/4    IPSEC/0x6370000F
Added key with SPI=0xc5bfbe3e into key list
80     09:45:07.943  10/01/13  Sev=Info/4    IPSEC/0x6370002F
Assigned VA private interface addr 192.168.2.70
81     09:45:07.943  10/01/13  Sev=Info/4    IPSEC/0x63700037
Configure public interface: 96.11.251.149. SG: **.**.***.***
82     09:45:07.943  10/01/13  Sev=Info/6    CM/0x63100046
Set tunnel established flag in registry to 1.
83     09:45:13.459  10/01/13  Sev=Info/4    IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to **.**.***.***
84     09:45:13.459  10/01/13  Sev=Info/6    IKE/0x6300003D
Sending DPD request to **.**.***.***, our seq# = 107205276
85     09:45:13.474  10/01/13  Sev=Info/5    IKE/0x6300002F
86     09:45:13.474  10/01/13  Sev=Info/4    IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:DPD_ACK) from **.**.***.***
87     09:45:13.474  10/01/13  Sev=Info/5    IKE/0x63000040
Received DPD ACK from **.**.***.***, seq# received = 107205276, seq# expected = 107205276
88     09:45:15.959  10/01/13  Sev=Info/4    IPSEC/0x63700019
Activate outbound key with SPI=0x1c4cafaa for inbound key with SPI=0xc5bfbe3e
89     09:46:00.947  10/01/13  Sev=Info/4    IKE/0x63000013
90     09:46:00.947  10/01/13  Sev=Info/6    IKE/0x6300003D
Sending DPD request to **.**.***.***, our seq# = 107205277
91     09:46:01.529  10/01/13  Sev=Info/5    IKE/0x6300002F
92     09:46:01.529  10/01/13  Sev=Info/4    IKE/0x63000014
93     09:46:01.529  10/01/13  Sev=Info/5    IKE/0x63000040
Received DPD ACK from **.**.***.***, seq# received = 107205277, seq# expected = 107205277
94     09:46:11.952  10/01/13  Sev=Info/4    IKE/0x63000013
95     09:46:11.952  10/01/13  Sev=Info/6    IKE/0x6300003D
Sending DPD request to **.**.***.***, our seq# = 107205278
96     09:46:11.979  10/01/13  Sev=Info/5    IKE/0x6300002F
97     09:46:11.979  10/01/13  Sev=Info/4    IKE/0x63000014
98     09:46:11.979  10/01/13  Sev=Info/5    IKE/0x63000040
Received DPD ACK from **.**.***.***, seq# received = 107205278, seq# expected = 107205278
Any help would be appreciated, thanks!
3 Accepted Solutions
Rashid Thompson
try putting you deny ACL (access-list AnyConnect_Client_Local_Print extended deny ip any any) at the end of the ACL list.
malshbou
Hi Matthew,
You use a VPN pool from the same subnet of the inside subnet (192.168.2.70 -192.168.2.80). This could lead to some unexpected behaviours. So i suggest that you use a unique pool and rely on routing to achieve communication between the inside subnet and the pool .
One question here, when the problem happens (after 30 seconds), is the tunnel kept up or you see the VPN client disconnected ?
The following troubleshooting will clarify the situation more :
  -  set the following captures:
       capture capin interface inside match ip host  < IP Assigned to the VPN client>   host
      if you cannot know the IP assigned to the client, use 192.168.2.0 255.255.255.0
   - connect from your VPN client
   - initiate a continous ping to the internal IP (set in the capture)
   - get the output of "show cap capin" from the ASA
   - get the outputs from the ASA :
      show crypto isakmp sa
      show crypto ipsec sa
  when the  problem starts:
   - "clear cap capin"
  - wait for seconds, and get the capture again: show cap capin
   - get the ASP drop captures
   cap asp type asp-drop all
   show cap asp
Hope this helps
Mashal Shboul
------------------ Mashal Shboul
Ok, i got them.
i will communicate with you via email.
Mashal Shboul
20 Replies 20
Rashid Thompson
malshbou
Hi Matthew,
   - "clear cap capin"
   show cap asp
Hope this helps
Mashal Shboul
matt020191
After the problem happens, the tunnel is kept up (the VPN client does not disconnect). All that changes is that the local network can no longer be accessed.
Attached is the capture you requested. From the VPN client to the server they access. I ran a continuous ping until it stopped responding, then stopped the captured and saved it. Let me know if that is what you needed.
Thanks so much for the replies!
Matthew
Matthew,
The captures you attached show normal traffic exchange for some period of time. However, the captures alone cannot point to the problem.
let's do the following when the problem is happening:
  - initiate a continous ping to the internal IP.
  Wait until the problem starts:
  -  run: "clear crypto ipsec sa counters"
  - wait for some seconds then get the following outputs from the ASA :
- set the captures:
    - get the ASP drop captures as following:
   show cap asp
Is it possible that you use a VPN pool different from the inside network range ?
Regards.
Mashal Shboul
Thanks for your quick reply!
I did exactly as you requested, and the results are attached.
As far as using a different set of IP addresses for the VPN pool, I have no problems with that at all, but would not know what to do to set up the routing so that the pool can access the internal network (I am not that familiar with Cisco CLI).
Matthew
Hi Matthew,
The SAs output shows that when the problem is happening, decaps are incresaing but no encaps, which indicates that the problem is in returning traffic from the internal hosts to the VPN pool. I didn't see any packets in the inside captures (capin), so based on that i assume that the arp consistency fails at some time from the internal hosts to the ASA.
I suggest that you get rid of this troublesome setup by using a distinct VPN pool. This change should be straighforward:
For example:
asa(config)# ip local pool NEW_POOL  192.168.3.1-192.168.3.254  255.255.255.0
address-pool NEW_POOL
You don't need to change routing in the internal subnet as long as it uses the ASA as a default gateway, otherwise you will need to add a specific route toward the new pool with the ASA as next-hop.
If you want to continue troublehsooting the current setup, you need to focus on captures at the inside host, ARP entries at the inside hosts, ARP debugs at the ASA, and captures at the ASA.
Hope this helps
Mashal Shboul
I made the change that you requested by moving the VPN pool to the 192.168.3.0 network. Unfortunately, now traffic isn't flowing to the inside network at all. I was going to make a specific route as you suggested, but as far as I can see the routes are already being created correctly on the VPN client's end.
Here is the route print off of the computer behind the (test) client:
Interface List
21...00 05 9a 3c 78 00 ......Cisco Systems VPN Adapter for 64-bit Windows
10...00 15 5d 01 02 01 ......Microsoft Hyper-V Network Adapter
15...00 15 5d 01 02 02 ......Microsoft Hyper-V Network Adapter #2
  1...........................Software Loopback Interface 1
13...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
11...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
14...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter
16...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
23...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
    69.61.228.178  255.255.255.255      96.11.251.1    96.11.251.149    100
      96.11.251.0    255.255.255.0         On-link     96.11.251.149    261
    96.11.251.149  255.255.255.255         On-link     96.11.251.149    261
    96.11.251.255  255.255.255.255         On-link     96.11.251.149    261
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
      192.168.1.0    255.255.255.0         On-link       192.168.1.3    261
      192.168.1.3  255.255.255.255         On-link       192.168.1.3    261
    192.168.1.255  255.255.255.255         On-link       192.168.1.3    261
      192.168.2.0    255.255.255.0      192.168.3.1     192.168.3.70    100
      192.168.3.0    255.255.255.0         On-link      192.168.3.70    261
     192.168.3.70  255.255.255.255         On-link      192.168.3.70    261
    192.168.3.255  255.255.255.255         On-link      192.168.3.70    261
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link       192.168.1.3    261
        224.0.0.0        240.0.0.0         On-link     96.11.251.149    261
        224.0.0.0        240.0.0.0         On-link      192.168.3.70    261
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link       192.168.1.3    261
  255.255.255.255  255.255.255.255         On-link     96.11.251.149    261
  255.255.255.255  255.255.255.255         On-link      192.168.3.70    261
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
          0.0.0.0          0.0.0.0      96.11.251.1  Default
IPv6 Route Table
Active Routes:
If Metric Network Destination      Gateway
14   1020 ::/0                     2002:c058:6301::c058:6301
14   1020 ::/0                     2002:c058:6301::1
  1    306 ::1/128                  On-link
14   1005 2002::/16                On-link
14    261 2002:600b:fb95::600b:fb95/128
                                    On-link
15    261 fe80::/64                On-link
10    261 fe80::/64                On-link
21    261 fe80::/64                On-link
10    261 fe80::64ae:bae7:3dc0:c8c4/128
                                    On-link
21    261 fe80::e9f7:e24:3147:bd/128
                                    On-link
15    261 fe80::f116:2dfd:1771:125a/128
                                    On-link
  1    306 ff00::/8                 On-link
15    261 ff00::/8                 On-link
10    261 ff00::/8                 On-link
21    261 ff00::/8                 On-link
Persistent Routes:
  None
And here is the updated running config in case you need it:
: Saved
ASA Version 8.4(1)
hostname NCHCO
enable password hTjwXz/V8EuTw9p9 encrypted
passwd hTjwXz/V8EuTw9p9 encrypted
names
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
 ip address 69.61.228.178 255.255.255.248
 speed 100
 duplex full
ftp mode passive
object network FINX
 host 192.168.2.11
object service rdp
 description rdp
object network obj-192.168.3.0
 subnet 192.168.3.0 255.255.255.0
object network obj-192.168.2.0
access-list outside_specific_blocks extended deny ip host 121.168.66.35 any
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
ip local pool VPN_Split_Pool 192.168.3.70-192.168.3.80 mask 255.255.255.0
arp timeout 14400
object network FINX
 webvpn
http server enable
http 69.61.228.178 255.255.255.255 outside
http 74.218.158.238 255.255.255.255 outside
 encryption 3des
 hash md5
 group 2
 lifetime 86400
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh 96.11.251.186 255.255.255.255 outside
ssh timeout 5
console timeout 0
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
webvpn
 ipsec-udp enable
 address-pools value VPN_Split_Pool
 address-pool VPN_Split_Pool
 strip-realm
 strip-group
 authentication pap
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
call-home
 profile CiscoTAC-1
  no active
Cryptochecksum:9e8466cd318c0bd35bc660fa65ba7a03
: end
Thanks again for your help,
Matthew
You need to add nat-exempt rule for the new VPN pool:
nat (inside,outside) source static NCHCO NCHCO destination static obj-192.168.3.0 obj-192.168.3.0
let me know how it goes with you.
Mashal Shboul
I did as you suggested above, but the traffic is still not getting to the 192.168.2.0 network. In trying to diagnose, I saw that the traffic was bypassing the tunnel in the VPN client (the packet count under Tunnel Details in VPN Client statistics show packets as bypassing). The VPN is set up as split tunneling, so I tried adding the 192.168.3.0 network to the ACL that specifies networks to tunnel but it did not make a difference. Any idea what would cause that?
Thanks once again,
Matt
If you go to Status -> Statistics -> Route Details in the VPN client, do you see the 192.168.3.0/24 network ?
Is the new behaviour happening with all clients ?
Mashal Shboul
No, under route details it only lists the 192.168.2.0/24 network. And yes, the new behavior is happening with all clients.
Matt
Yes i meant 192.168.2.0/24 ( the inside subnet). That should be enough.
So you don't see the " Encrypted" counter increasing at all ?
If so, please attach the output of "ipconfig  /all" from an affected PC. I will need to make a lab reproduction to investigate the details.
Mashal Shboul
Unfortunately, no, the encyrpted packet count is not increasing, all of the traffic is bypassed.
Here is the ipconfig /all from the machine I am using to test:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : psaserver
   Primary Dns Suffix  . . . . . . . : mtec.local
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : NCHCO.local
                                       mtec.local
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . : NCHCO.local
   Description . . . . . . . . . . . : Cisco Systems VPN Adapter for 64-bit Windows
   Physical Address. . . . . . . . . : 00-05-9A-3C-78-00
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::e9f7:e24:3147:bd%21(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.3.70(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . :
   DHCPv6 IAID . . . . . . . . . . . : 469763482
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-B2-4E-DD-00-15-5D-01-02-01
   DNS Servers . . . . . . . . . . . : 192.168.2.1
                                       8.8.8.8
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Direct Modem:
   Description . . . . . . . . . . . : Microsoft Hyper-V Network Adapter
   Physical Address. . . . . . . . . : 00-15-5D-01-02-01
   Link-local IPv6 Address . . . . . : fe80::64ae:bae7:3dc0:c8c4%10(Preferred)
   IPv4 Address. . . . . . . . . . . : 96.11.251.149(Preferred)
   Default Gateway . . . . . . . . . : 96.11.251.1
   DHCPv6 IAID . . . . . . . . . . . : 234886493
   DNS Servers . . . . . . . . . . . : 192.168.1.2
Ethernet adapter Server Local Area Connection:
   Description . . . . . . . . . . . : Microsoft Hyper-V Network Adapter #2
   Physical Address. . . . . . . . . : 00-15-5D-01-02-02
   Link-local IPv6 Address . . . . . : fe80::f116:2dfd:1771:125a%15(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 335549789
Tunnel adapter isatap.{9BF1C548-7214-41BD-82B8-6C1FCD87D0D9}:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 9:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter 6TO4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter
   IPv6 Address. . . . . . . . . . . : 2002:600b:fb95::600b:fb95(Preferred)
   Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
                                       2002:c058:6301::1
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{FA90FDD2-5A85-494D-9027-D913EC264276}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.NCHCO.local:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
And the ouitput of "route print" while the VPN is connected. Btw, what is the IP you try to ping ?
Mashal Shboul
