11-12-2006 11:18 AM - edited 02-21-2020 02:43 PM
Hello
I am using vpn client version 4.8 to access my LAN behind a PIX 515 ver 6.3, the tunnel is not working, a debug output is included in the attached file.
thank you for any suggestion
11-12-2006 11:52 AM
hi from ur config it looks like there is a acl which is blocking the connections. it would be better for ur if u cna post ur pix config.
regards
sebastan
Log in to Community
