topology
CVPN on winxp --> 1600 w/ NAT&DHCP --> internet <--> IOS VPN on 2600.
I am able to est the tunnel over the NAT however I can not reach host or networks beyond or on the VPN router.
here is my VPN config:
username VPN_CLIENT password xxxxx
aaa new-model
aaa authentication login VPNCLIENTS local
aaa authorization network VPNCLIENTS local
aaa session-id common
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration address-pool local VPN_POOL
crypto isakmp client configuration group VPN_CLIENT
key xxxx
pool VPN_POOL
crypto ipsec transform-set VPN_CLIENT esp-3des esp-sha-hmac
no crypto ipsec nat-transparency udp-encaps
crypto dynamic-map VPN_DYNAMIC 1
set transform-set VPN_CLIENT
reverse-route
crypto map VPN_CLIENT client authentication list VPNCLIENTS
crypto map VPN_CLIENT isakmp authorization list VPNCLIENTS
crypto map VPN_CLIENT client configuration address respond
crypto map VPN_CLIENT 1 ipsec-isakmp dynamic VPN_DYNAMIC
interface FastEthernet0/0
ip address 10.202.151.xxx 255.255.255.224
speed 100
full-duplex
interface FastEthernet0/1
ip address 64.60.42.xxx 255.255.255.0
speed 100
full-duplex
router eigrp 75
passive-interface FastEthernet0/1
network 10.0.0.0
distribute-list 10 in
no auto-summary
ip local pool VPN_POOL 192.168.200.1 192.168.200.10
ip route 0.0.x.x.x.x.0 64.60.42.1
