Running two different Tunnels over 1 GRE: Issues
Kaushik Ray
Hello All
I am having an issue setting up two separate tunnels running over a single GRE; is this something that is possible?
Would be grateful to have you advice.
I am able to ping across the tunnel (120) using the VRF but as soon as i am adding tunnel 121 which is native (not using vrf) i can ping across the new tunnel 121 but cannot ping the original tunnel 120
Background of the setup.
R1  ------- Internet -------- R2
R1
crypto keyring IPsec-KEY vrf Internet
  pre-shared-key address 0.0.0.0 0.0.0.0 key KEY
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
lifetime 28800
crypto isakmp invalid-spi-recovery
crypto isakmp profile ISAKMP-profile
   keyring IPsec-KEY
   match identity address 0.0.0.0 Internet
crypto ipsec transform-set trans esp-aes esp-md5-hmac
mode transport
crypto ipsec profile IPSEC-profile
set security-association lifetime seconds 86400
set transform-set trans
set pfs group2
set isakmp-profile ISAKMP-profile
interface Tunnel120
vrf forwarding mgmt
bandwidth 256
ip address 10.169.9.81 255.255.255.252
ip mtu 1376
ip tcp adjust-mss 1360
tunnel source Loopback810
tunnel destination xxx.xxx.xxx.xxx
tunnel vrf Internet
tunnel protection ipsec profile IPSEC-profile shared
R2 mirrors this config but as soon as i add tun 121 with the following config i get connectivity to the 121
tunnel 121 i configured as follows:
interface Tunnel121
ip address 10.190.12.249 255.255.255.252
ip mtu 1376
tunnel vrf Internet
Please advice if I am making some errors?
Also let me know if any more information is required on this.
Thanks in advance,
15 Replies 15
Thanks for your response and your thoughts and views on this.
I have noted your suggestion regarding the config and will keep in mind hence forth.
Many Thanks
again
Kaushik
