Running two different Tunnels over 1 GRE: Issues
Kaushik Ray
Hello All
I am having an issue setting up two separate tunnels running over a single GRE; is this something that is possible?
Would be grateful to have you advice.
I am able to ping across the tunnel (120) using the VRF but as soon as i am adding tunnel 121 which is native (not using vrf) i can ping across the new tunnel 121 but cannot ping the original tunnel 120
Background of the setup.
R1  ------- Internet -------- R2
R1
crypto keyring IPsec-KEY vrf Internet
  pre-shared-key address 0.0.0.0 0.0.0.0 key KEY
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
lifetime 28800
crypto isakmp invalid-spi-recovery
crypto isakmp profile ISAKMP-profile
   keyring IPsec-KEY
   match identity address 0.0.0.0 Internet
crypto ipsec transform-set trans esp-aes esp-md5-hmac
mode transport
crypto ipsec profile IPSEC-profile
set security-association lifetime seconds 86400
set transform-set trans
set pfs group2
set isakmp-profile ISAKMP-profile
interface Tunnel120
vrf forwarding mgmt
bandwidth 256
ip address 10.169.9.81 255.255.255.252
ip mtu 1376
ip tcp adjust-mss 1360
tunnel source Loopback810
tunnel destination xxx.xxx.xxx.xxx
tunnel vrf Internet
tunnel protection ipsec profile IPSEC-profile shared
R2 mirrors this config but as soon as i add tun 121 with the following config i get connectivity to the 121
tunnel 121 i configured as follows:
interface Tunnel121
ip address 10.190.12.249 255.255.255.252
ip mtu 1376
tunnel vrf Internet
Please advice if I am making some errors?
Also let me know if any more information is required on this.
Thanks in advance,
2 Accepted Solutions
no, I mean the following:
interface Tunnel120
  tunnel key 120
interface Tunnel121
  tunnel key 121
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
With a config that uses VRFs like in your scenario I get the same result of UP-NO-IKE. But with the relevant show-commands you can see that the ISAKMP-SA is build and available. I also didn't see any negative impact on the function of the various tunnels so for me it seems that it works as it should.
Some more feedback on your config:
  1. Group2 is more or less a DH-group that should phased out. Start to move to group5 or group 14 where possible.
  2. You mtu/mss-settings are not conclusive. With an mss of 1360 the mtu of 1376 (and why are they set on the tunnel) doesn't make any sense with an ip/tcp-header of 40 bytes.
  3. If you know your peers, it's better to avoid wildcard-PSKs. Better use one PSK only for one connection.
Happy X-Mas!
15 Replies 15
I think in a scenario like this you need different tunnel-keys on both tunnels to make that work.
Thanks a lot Karsten for your reply; by different tunnel key on each tunnel you mean
for tu 120
crypto keyring IPsec-KEY1 vrf Internet
  pre-shared-key address 0.0.0.0 0.0.0.0 key KEY1
and  for tu 121
crypto keyring IPsec-KEY2 vrf Internet
  pre-shared-key address 0.0.0.0 0.0.0.0 key KEY2
and create separate isakmp profiles and the follow the whole process?
thanks again
interface Tunnel120
  tunnel key 120
interface Tunnel121
  tunnel key 121
Thanks a lot Karsten for your advice on this. this is working; do not know how to thank you!
Karsten
one more thing I am seeing on this is the following; one of the tunnels stay "UP-NO-IKE" is it something that is normal?
I have added the command crypto isakmp invalid-spi-recovery either end but the VPN status stays like this.
Crypto session current status
Interface: Tunnel120 Tunnel121
Session status: UP-NO-IKE
Peer: xxx.xxx.xxx.xxx port 500
  IPSEC FLOW: permit 47 host xxx.xxx.xxx.xxx host xxx.xxx.xxx.xxx
        Active SAs: 2, origin: crypto map
Interface: FastEthernet0/0
Profile: ISAKMP-profile
Session status: UP-IDLE
  IKE SA: local xxx.xxx.xxx.xxx/500 remote xxx.xxx.xxx.xxx/500 Active
Your "UP-NO-IKE" is caused by your quite uncommon lifetime-config. Your ISAKMP has a shorter lifetime then the IPsec-SAs. After 28800 seconds your ISAKMP gets deleted but your IPsec SA stay up. Thats what you see with UP-NO-IKE. The normal way to configure it is to have a longer lifetime for ISAKMP then for IPsec.
thanks again i changed the config either end
encr aes
group 2
set security-association lifetime seconds 78800
set transform-set trans-hcc
set pfs group2
cleared crypto
and established the tunnel once more but it comes back
how did you clear the crypto? And have checked that they were really gone?
Did the following:
RTR#clear crypto ses
RTR#sh crypto session
Session status: DOWN
        Active SAs: 0, origin: crypto map
Session status: DOWN-NEGOTIATING
  IKE SA: local xxx.xxx.xxx.xxx/500 remote xxx.xxx.xxx.xxx/500 Inactive
RTR#ping 10.190.12.249 repeat 10
Sending 10, 100-byte ICMP Echos to 10.190.12.249, timeout is 2 seconds:
Success rate is 90 percent (9/10), round-trip min/avg/max = 1/3/4 ms
I can't reproduce that. What's your complete config and IOS-version?
The Two Routers have the following IOS versions
c2800nm-adventerprisek9-mz.150-1.M9.bin
2800nm-advipservicesk9-mz.124-22.T5.bin
I will pass on the whole configs; could the fact be that since i am using version 15 on one which is normally for ISR G2 it could be causing problems?
I don't think so. I'm also running nearly everywhere IOS 15.0/15.1/15.2 but some sites still have 12.4T and there are no problems.
Thanks i have sent you the whole configs in a private message
Happy X-Mas!
