Satellite Connection and VPN
Prudence
I am just starting to investigate establishing a VPN using satellite connections. I have heard that Cisco routers will not work in this situation. If anyone has any feedback on this particular issue or the topic in general, I would appreciate your response. Our company is providing high speed internet connection to rural areas using Direct PC dishes with satellite connections.
Thank you
5 Replies 5
bbaley
Level 3
Level 3
Too much latency between the dial-up and the inbound satellite feed. Satellite networking is best for web-browsing and more traditional TCP applications.
graymcrdr
I use Dish network satellite at home and PPTP into a PIX at work. It is slow but it works.
I have a user with the same latency issues. Does anyone know why that happens? Is their any problems/issues with creating a VPN tunnel within a VPN (I believe that is what satellite is using.)
Erik
I have a user that will have the 2-way satellite feed(no dial up involved at all) Does any one have experience with this setup? I don't think I should run into the same latency problems correct?
I have a remote office with Winstar using a Cisco 3002 VPN Hardware Client.
Client <-> 3002 <-> Cisco SOHO Router <-> Winstar
It has been the most stable of all configurations -the others including DSL. Cable and ISDN.
Been a good experience.
