Simple IOS VPN IPsec HUB and Spoke with Failover HUB
l.buschi
Level 2
Level 2
Hi all,
I have a Hub nd Spoke  VPN architecture realized with sVTI, IKEv1 and IPsec.
My hub is connected to a single ISP.
I'd like to have an hardware redundancy for my hub.
Instead of creating a double tunnel in each spoke i'd like to use a failover protocol over my 4000ISR router.
Is there a way to realize it simply?
If I use IOS IPsec failover do I have to deploy my changes on  both router or (like ASA) I may configure the active router and let the standby receive the chenges?
Thank you all.
Johnny
rvarelac
Level 7
Level 7
Hi Johnny,
Which redundancy solution are you planning to implement on the Cisco ISR ?
HSRP with another hardware box might fit well here:
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-ipsec/white_paper_c11_472859.html
Hope it helps
-Randy-
