Site to Site VPN problem between Cisco ASA and Checkpoint
LogicalTRC TRC
I am having a problem with a Site to Site VPN between my Cisco ASA  8.2(5) and Checkpoint (unknown version at this point).  VPN establishes okay, but the Check point has been dropping the VPN (I think) and we get the following on the ASA.
24  IKE Peer: 170.163.45.2
    Type    : L2L             Role    : responder
    Rekey   : no              State   : MM_REKEY_DONE_H2
25  IKE Peer: 170.163.45.2
    Type    : L2L             Role    : initiator
    Rekey   : yes             State   : MM_ACTIVE_REKEY 24  IKE Peer: 170.163.45.2
Once I clear the IKE SA, then VPN reestablishes.  I am looking to see if there is a fix for this.
Chuck Slayton
Azubuike Obiora
Hi Chuck,
Do you have access to the Checkpoint firewall? I am aware that in some version of Checkpoint software, there's an additional configuration needed to make the tunnel solid from the Cisco stand point.
From what I can see here, it's basically a phase 1 problem.
Teddy
I don't have direct access to it, but I'm working with an engineer that does.  Let me know what you need from the Check Point site of things, version, configuration, etc.
Chuck
The checkpoint FW is running Gaia R75.47.  Let me know the additional configuration needed to make the tunnel solid.
Chuck
any update on this? We're having the same issue
