Strange IPSec VPN Client Problem
limlayhin
My company had recently bought a pair of new cisco 5525-CX.
I encountered very strange problem in remote-access VPN setup in this device.
I can successfully login to VPN. However, after login, I can only access HTTPS web site, I cannot acces HTTP and I cannot do SSH.
If I will to use packet sniffer on my vpn client labtop, I saw initial TCP handshaking was successful. After that, I saw retransmission repeatedly, as if the destination server didn't receive request from the vpn client labtop.
I can reproduced same problem in both set of firewalls.
Config as below:
ASA Version 9.1(1)
hostname MYFIREWALL
ip local pool myvpn-ippool 10.10.9.65 mask 255.255.255.255
interface GigabitEthernet0/0
speed 1000
duplex full
nameif OUTSIDE
security-level 0
ip address 123.123.123.123 255.255.255.240
ipv6 enable
interface GigabitEthernet0/4
speed 1000
duplex full
nameif INTERNAL-MGT
security-level 100
ip address 10.10.10.254 255.255.255.0
ipv6 enable
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network MYVPN-IP-NAT-PUB
host 10.10.9.65
object network MYVPN-IP-PUB
host xx.xx.xx.65
access-list MYVPN-ACL extended permit ip any any
nat (OUTSIDE,OUTSIDE) static MYVPN-IP-PUB
route OUTSIDE 0.0.0.0 0.0.0.0 123.123.123.169 1
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map OUTSIDE_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map OUTSIDE_map interface OUTSIDE
crypto ca trustpool policy
crypto ikev1 enable OUTSIDE
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
group-policy MYVPN-SET1 internal
group-policy MYVPN-SET1 attributes
wins-server none
dns-server value xx.xx.xx.xx xx.xx.xx.xx
vpn-filter value MYVPN-ACL
vpn-tunnel-protocol ikev1
group-lock value MYVPN-SET1
default-domain value myvpn.com
tunnel-group MYVPN-SET1 type remote-access
tunnel-group MYVPN-SET1 general-attributes
address-pool myvpn-ippool
default-group-policy MYVPN-SET1
tunnel-group MYVPN-SET1 ipsec-attributes
ikev1 pre-shared-key *****
tunnel-group MYVPN-SET1 ppp-attributes
authentication pap
authentication ms-chap-v2
deshtikypshaq
I did not fint that you apply MYVPN-ACL to any interface. Is it true?
It is applied to group policy.
wins-server none
Check your vpn-filter ACL as it is stating permit ip any any. By default, if you don't configure split-tunnel and vpn-filter all traffic from client goes via tunnel. There is no need to configure vpn-filter if you dont want to restrict any traffic.
Remove this VPN Filter.
VPN Filters consist of rules that determine whether to allow or reject tunneled data packets that come through the security appliance, based on criteria such as source address, destination address, and protocol.
When a vpn-filter is applied to a group-policy/user name mode that governs Remote Access VPN Client connections, the ACL must be configured with the client assigned IP addresses in the src_ip position of the ACL and the local network in the dest_ip position of the ACL.
"Please rate helpful posts"
