Telnet through webVPN in ASA problem
srivero
Hello. I've configured in an ASA5540 (8.4) access to a server in my LAN using telnet with webVPN. I've installed the ssh/telnet plug-in in the ASA and SSH access to the servers works fine but when I try telnet access I always get this error:
Sorry, Could not connect to: "ip server" 23
Reason: java.io.IOException: Connection failed
It happen with any server I try. I'm not trying to access to the ASA, just servers inside my LAN that I can access with anyconnect correctly. There is a Cisco bug (CSCsq89467) saying that not configuring any Web-acl in the ASA solve the problem. I haven't anyone and the telnet always show the same error.
ajay chauhan
Level 7
Level 7
Please post your configuration.
Meanwhile check if you can telnet on that host locally to check if services for 23 is on.
Ajay
