08-05-2005 01:34 PM
Hi all,
I have ran out of ideas on this.I have 2 sites VPN'ed and working ok. Site1 is connected to the web thru ADSL on a 837 router (IOS 12.3(2)XC2). Now I must setup the 837 for Easy VPN server for Cisco VPN clients. I've tried with SDM, which made the config below:
(VPNClient Remote pool is 10.10.250.0/24, Site1 LAN is 10.10.10.0/24, Site2 LAN is 10.10.20.0/24, Site1 public IP is A.B.C.D, Site2 public IP is E.F.G.H)
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization network sdm_vpn_group_ml_1 local
<<<isakmp policies i think are fine>>>
crypto isakmp key 0 site-site-key address E.F.G.H no-xauth
crypto isakmp client configuration group REMOTE-VPN
key 0 client-site-key
dns M.N.O.P
pool REMOTE-POOL
acl 100
save-password
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set TR1 esp-3des esp-sha-hmac
crypto ipsec transform-set TR2 esp-3des esp-md5-hmac
crypto dynamic-map DYNMAP_1 1
description User to Site VPN Clients
set security-association lifetime seconds 3600
set transform-set TR1
set pfs group2
match address 100
reverse-route
crypto map MAP1 client authentication list sdm_vpn_xauth_ml_1
crypto map MAP1 isakmp authorization list sdm_vpn_group_ml_1
crypto map MAP1 client configuration address respond
crypto map MAP1 100 ipsec-isakmp
set peer E.F.G.H
set security-association lifetime kilobytes 2097152
set security-association lifetime seconds 43200
set pfs group2
match address 130
reverse-route
crypto map MAP1 65535 ipsec-isakmp dynamic DYNMAP_1
interface Dialer1
ip address negotiated
ip access-group 121 in
ip inspect myfw out
crypto map MAP1
ip local pool REMOTE-POOL 10.10.250.1 10.10.250.254
ip nat inside source route-map nonat interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 100 permit ip 10.10.0.0 0.0.255.255 any
access-list 102 deny ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 102 deny ip 10.10.0.0 0.0.255.255 10.10.250.0 0.0.0.255
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
access-list 121 permit ip 10.10.250.0 0.0.0.255 10.10.0.0 0.0.255.255
access-list 121 permit ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 121 permit ip 10.10.250.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 121 permit ip 10.10.250.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 121 permit udp any eq domain 10.10.10.0 0.0.0.255
access-list 121 permit udp any any eq isakmp
access-list 121 permit ahp host E.F.G.H any
access-list 121 permit ahp any any
access-list 121 permit esp host E.F.G.H any
access-list 121 permit esp any any
access-list 121 permit udp host E.F.G.H any eq isakmp
access-list 121 permit udp host E.F.G.H any eq non500-isakmp
access-list 121 permit udp any any eq non500-isakmp
access-list 121 permit udp any any eq 10000
access-list 121 permit icmp any host A.B.C.D
access-list 121 deny ip any any log
access-list 130 permit ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
route-map nonat permit 10
match ip address 102
Thou site-to-site VPN works ok I can't get the cisco client to connect a tunnel to the router, yet it communicates with it.
Here's part of the router debug :
ISAKMP (0:2): sending packet to 213.103.218.139 my_port 500 peer_port 500 (R) AG_INIT_EXCH
ISAKMP (0:2): Input = IKE_MESG_FROM_AAA, PRESHARED_KEY_REPLY
ISAKMP (0:2): Old State = IKE_R_AM_AAA_AWAIT New State = IKE_R_AM2
ISAKMP (0:2): received packet from 213.103.218.139 dport 500 sport 500 Global (R) AG_INIT_EXCH
%CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from 213.103.218.139 was not encrypted and it should've been.
ISAKMP (0:2): incrementing error counter on sa: reset_retransmission
Thanx alot for any help provided. I have no idea what to try next with this.
regards
Aurélien
08-08-2005 08:41 PM
Try removing the 'match address 100' statement from the dynamic-map config.
Shijo George.
08-09-2005 12:42 AM
Thanks - I have done this and there is a progress : now from the VPN client I get the Xauth dialog box prompting for username/password. But after i have entered credentials it still fails to establish the tunnel.
i believe that now phase 1 completes and failure is in phase 2, if i refer to the router debugs :
(VPNClient Remote pool is 10.10.250.0/24, Site1 LAN is 10.10.10.0/24, Site2 LAN is 10.10.20.0/24, Site1 public IP is A.B.C.D, VPN client public IP is VPN.CLIENT.IP.ADDR)
ISAKMP (0:3): Checking IPSec proposal 11
ISAKMP: transform 1, ESP_3DES
ISAKMP: attributes in transform:
ISAKMP: authenticator is HMAC-MD5
ISAKMP: encaps is 61443
ISAKMP: SA life type in seconds
ISAKMP: SA life duration (VPI) of 0x0 0x20 0xC4 0x9B
ISAKMP (0:3): atts are acceptable.
IPSEC(validate_proposal_request): proposal part #1,
(key eng. msg.) INBOUND local= A.B.C.D, remote= VPN.CLIENT.IP.ADDR,
local_proxy= 0.0.0.0/0.0.0.0/0/0 (type=4),
remote_proxy= 10.10.250.13/255.255.255.255/0/0 (type=1),
protocol= ESP, transform= esp-3des esp-md5-hmac ,
lifedur= 0s and 0kb,
spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x400
IPSEC(validate_transform_proposal): invalid transform proposal flags -- 0x400
ISAKMP (0:3): IPSec policy invalidated proposal
ISAKMP (0:3): phase 2 SA policy not acceptable! (local A.B.C.D remote VPN.CLIENT.IP.ADDR)
ISAKMP (0:3): Input = IKE_MESG_FROM_PEER, IKE_INFO_DELETE
ISAKMP (0:3): Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
IPSEC(key_engine): got a queue event with 1 kei messages
IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
and here's my modified config (part of) :
crypto isakmp key 0 site-site-vpn-key address E.F.G.H no-xauth
crypto isakmp keepalive 20 10
crypto isakmp nat keepalive 20
crypto isakmp xauth timeout 20
crypto isakmp client configuration group SITAB-REMOTE-VPN
key 0 client-site-vpn-key
dns 80.10.246.130 80.10.246.3
pool REMOTE-POOL
acl 103
save-password
crypto ipsec transform-set TR3 esp-3des esp-md5-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set TR3 TR2 TR1
set pfs group2
reverse-route
set peer E.F.G.H
set pfs group2
match address 130
reverse-route
crypto map MAP1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
interface Dialer1
crypto map MAP1
access-list 102 deny ip any 10.10.250.0 0.0.0.255
access-list 103 permit ip 10.10.0.0 0.0.255.255 any
Any idea where the problem comes from ? I am suspicious about the debug message "IPSEC(validate_transform_proposal): invalid transform proposal flags -- 0x400"
I could not find any helpful info about this so far...
Thanks again for all help provided.
Aurélien
09-02-2005 07:18 AM
Sorry i will not help you, i just want to know if you have solved your problem ?
Olivier
09-04-2005 12:11 AM
This issue was solved with help of Cisco expert Haseeb Niazi in this forum. It needed PFS removed from the dynamic crypto map. It is now working.
Aurelien
