Using Cisco VPN client can't ping beyond inside interface
tony
I have a ASA 5505 7.2(3)
The firewall is set up w/ A inside IP network of 192.168.55.0
The VPN pool is setup as 192.168.55.90-192.168.55.99
What do I need to enable or create to allow the outside vpn clients to access the inside servers?
9 Replies 9
ajagadee
You need to bypass NAT for the VPN Client Traffic by configuring nat (inside) 0.
nat (inside) 0 access-list 101
access-list 101 extended permit ip 192.168.55.0 255.255.255.0 192.168.55.0 255.255.255.0
Please refer the below URL for configuration details.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008080f2d1.shtml
While the above configuration should most likely resolve the issue, I would recommend that you configure a different subnet for the VPN Client Pool, something that is not part your internal network and then include them in the NAT 0 Command. Depending upon your routing domain and how things are configured, you could run into routing issues by assigning IP Address for the VPN Clients from your internal network.
Arul
*Pls rate if it helps*
I made the necessary changes to the vpn pool as requested. Now I am unable to ping the gateway of 192.168.55.1 The vpn pool is 192.168.75.0 225.255.255.0. I am attaching the updated config. Could any help?
ajagadee
Couple of things:
1. You split tunnel is misconfigured.
access-list PCGRemoteAccess_splitTunnelAcl standard permit 192.168.75.0 255.255.255.0
The above ACL should be
access-list PCGRemoteAccess_splitTunnelAcl standard permit 192.168.55.0 255.255.255.0
Basically, split tunnel specifies what addresses you want the VPN Remote Users to access over the tunnel.
2. Your NAT (inside) 0 is misconfigured.
access-list 101 extended permit ip 192.168.75.0 255.255.255.0 192.168.75.0 255.255.255.0
This should be
access-list 101 extended permit ip 192.168.55.0 255.255.255.0 192.168.75.0 255.255.255.0
Please do make the changes and test the tunnel connectivity.
Arul
Made changes no difference. The tunnel is being built correctly but no traffic flow. I can't ping the 192.168.55.1 interface or any inside address.
Still need help. Anybody out there?
post your latest config please.
Here you go
Made change to access-list:
Still doesn't work, but corrected as suggested.
ajagadee
Tony,
After you made the changes to the configuration, did you do "clear xlate" and then try pinging an IP Address on the 192.168.55.0 subnet.
Also, after connecting the VPN Client and trying to access something on the inside, can you post the outputs of "show cry is sa" and "show cry ipsec sa"
Arul
