Using Crypto Maps and IPsec Static VTI's on the same router
John Platts
Level 4
Level 4
Is it possible to configure both crypto maps and IPsec static VTI's on the same router? What platforms have this capability? What IOS version do I need?
uwkleinh
Yes you can and as far as I know I dont think there is a hardware dependency.
VTI mode 'tunnel mode ipsec ipv4' was added in 12.3(14)T.
If you are mixing tunnel protection and crypto map ensure you use iskmp profiles to differentiate somehow that the tunnel IPSec connection is not prcessed on the crypto map!
Here is a rough example (fine tune it as needed):
crypto keyring key1
  pre-shared-key address 1.1.1.1 key test123
crypto keyring key2
  pre-shared-key address 7.7.7.7 key test777
crypto isakmp profile vpn1
   keyring key1
   match identity address 1.1.1.1 255.255.255.255
crypto isakmp profile vpn2
   keyring key2
   match identity address 7.7.7.7 255.255.255.255
crypto ipsec transform-set test esp-des esp-sha-hmac
crypto IPsec profile vpn-tunnel
set transform-set test
set isakmp-profile vpn1
crypto map mymap 1 ipsec-isakmp
set peer 7.7.7.7
set isakmp-profile vpn2
match address 177
interface Tunnel0
ip address 10.0.51.217 255.255.255.0
tunnel source 2.2.2.2
tunnel destination 1.1.1.1
tunnel protection ipsec profile vpn-tunnel
interface Ethernet4
ip add 2.2.2.2 255.255.255.0
crypto map mymap
Uwe
Самое главное отличие будет в том, что на удаленных устройствах в этом случае б в самом crypto-acl будут лишь два адреса, зеркальные адресам, указанным как tunnel source и tunnel destination на 2921. По идее, больше никаких изменений.
