using same ip adress for VPN and inside interface
francis.labelle
Hi, I want to know if it's possible on a ASA to use the same IP on the LAN and on the VPN. My user has actually a fixed ip on the LAN and I would like to reuse the same IP when they are connect to the VPN.
The target is to allowed/restric the same thing when they are on the VPN or on the LAN.
Thank !
spremkumar
Level 9
Level 9
Hi Francis
You can provide ips from the same ip block which is being used in the local lan , but its always advisable to provide ips from different block altogether.
regds
