VPN connection problem
trietgiang
Level 2
Level 2
Hi everyone,
I connect a Draytek router to Cisco router using VDPN. I have run "debug crypto isakmp" on our Cisco router. The SA was authenticated but the connection wasn't established. The show crypto session said the connection was DOWN-NEGOTIATING.
Do you know why it doesn't establish the connection?
Thank you very much.
Triet
6 Replies 6
Not applicable
Make sure that crypto map which allows the interesting traffic is configured right and applied to the appropriate outgoing interface to bring the tunnel up.
Thanks Pengke11, I can confirm the settings are correct.
purohit_810
Level 9
Level 9
Do you have port open 4500 i.e. for NAT-T??
Dharmesh
Dharmesh, thank you for your reply.
No I don't have port 4500 open. Why does it need to be opened?
Best regards,
Triet
Yes I already have port NAT-T open, just didn't realise that "non500-isakmp" is actually 4500.
trietgiang
Level 2
Level 2
Hi again,
I have finally had the VPN working between a Draytek and a Cisco router. Both on dynamic IP. I wrote down as a blog, check it out if you need to:
http://trietgiang.blogspot.com/2008/04/dialin-vpn-from-draytek-to-cisco.html
