11-30-2011 07:11 AM
Hello guys. we have site to site vpn .. and here is my scenairio .
Site A ( ASA 5505 )\
VLAN 1 - outside = 200.200.200.x -- internet
VLAN 2- inside 192.168.8.1
Eth0/1 --- 192.168.8.2
255.255.255.0
Gateway 192.168.8.1
This is My Laptop
Eth0/1 192.168.8.3
255.255.255.0
no gateway.
LINUX Server
So my remote VPN site B can reach my laptop ip 192.168.8.2 because of the gateway i put it
but it can't reach My Linux Sesrver 192.168.8.3 because it has not gatway.
and i don't want to add a gatway my server for some reasons .. so please can any one help me here it's very importan for me.
Solved! Go to Solution.
11-30-2011 07:22 AM
You will have to add gateway no other option to get the connectivity.
Ajay
12-06-2011 01:12 AM
Hello Thomas, hope you must be doing fine! have you got the response or you still looking for further response. Please mark this as answered and also rate the discussion incase your query is resolved. Appreciate your time. Regards, Ankur Community Manager: Security and VPN
11-30-2011 07:22 AM
Ajay
11-30-2011 07:49 AM
if i add a route to LINUX Server , is it possible that my remote site VPN Can reach
11-30-2011 07:53 AM
or if i remove the VLAN interface ip . and put it no ip address to VLAN 1. is that is possible to reach the server without gateway
11-30-2011 09:04 AM
Ading route on linux machine should do you can test it not very much sure why not putting the gateway but the route.
Ajay
12-02-2011 10:04 PM
Ajay -- if i put my inside with NO IP address .. can site B Reach my server. i want to avoid to put the gateway my server . so any other idea please
Thank You
12-04-2011 03:35 PM
Hello Thomas,
As mentioned by Ajay you must add a static route on the Linux box.
By adding a route for the remote network you are not defining a default-gateway but a next-hop.
Hope it helps.
12-06-2011 01:12 AM
12-06-2011 06:48 AM
Thank you all it works fine..
