VPN Problem between VPN Concentrator and CheckPoint
susanto_leman
I have vpn problem between cisco vpn concentrator and checkpoint. The vpn tunnel can not be established after period of time. Its up on the cisco vpn concentrator but its down on checkpoint.
I have found this bug on cisco website but THERE'S NO WORKAROUND ?????
anybody know how to solve this problem ?
thanks
CSCea04137
There is a problem with IPSEC SAs reestablishing after checkpoint initiates a soft reset.
sachinraja
Level 9
Level 9
hi..
what is the IOS version in the VPN concentrator.. try using a higher version of IOS.. probably this bug would have been rectified on the new version.. try with 4.1.5 , if u dont have this already..
all the best.. rate replies if found useful..
raj
