Weird IPsec L2L problem
campbech1
Level 5
Level 5
I'm getting the error message in my syslog showing the remote user is going after 0.0.0.0 even though the decrypted packet is showing 10.200.130.x
11-16-2007 10:42:53 Local4.Warning 10.200.x.x Nov 16 2007 10:42:53 BHG-FW : %ASA-4-402116: IPSEC: Received an ESP packet (SPI= 0xC3FABF97, sequence number= 0x2) from 207.59.x.x (user= 207.59.x.x) to Outside_PAT. The decapsulated inner packet doesn't match the negotiated policy in the SA. The packet specifies its destination as 10.200.x.x, its source as 207.59.x.x, and its protocol as 6. The SA specifies its local proxy as 0.0.0.0/255.255.255.255/0/0 and its remote_proxy as 207.59.x.x/255.255.255.255/0/0.
Any ideas what is going on here? I only get this far if I put the local network as any, if I specify the 3 hosts that I only want to allow access to nothing works.
timkaye
Level 5
Level 5
Do your ACL's at each end match exactly?
