WS-C3750X-48P has ssh connection problem
blankguy7
Hi everyone,
This system is running since about 2 years without problems (3x stackables switches) and suddendly we cannot access it with ssh.
I've upgraded it to this last version : c3750e-ipbasek9-mz.150-2.SE9.bin.
After the upgrade and reboot this issue remains present and I don't know at all what could be the problem?
Switches:
Switch Ports Model SW Version SW Image
* 1 54 WS-C3750X-48P 15.0(2)SE9 C3750E-IPBASEK9-M
2 54 WS-C3750X-48P 15.0(2)SE9 C3750E-IPBASEK9-M
3 54 WS-C3750X-48 15.0(2)SE9 C3750E-IPBASEK9-M
Issue:
$ ssh -l admin xxxxxxx
bash: connect: Connection refused
bash: /dev/tcp/xxxxxxx/22: Connection refused
bash: 3: Bad file descriptor
bash: line 0: kill: (15411) - No such process
ssh_exchange_identification: Connection closed by remote host
Could someone has an ideas? or know what is the problem?
Thank you for your help
Best regards,
J.
Have you issued the commands below? With the ip domain-name command, use whatever domain name your production switches use. With the crypto key generate rsa, when asked for the length of the key you may put 1024. If there was already an rsa key generated, try to remove it by issuing the command crypto key zeroize rsa then generate a new one.
ip domain-name example.com
ip ssh version 2
On the line vty, make sure you have login local or password set if you don't use tacacs. With the way you are logging in remotely through ssh is not from a terminal emulator like putty or secure crt and I don't know if it matters, but check if you have the option to specify version 2. For example if I want to ssh from a Cisco switch to another switch that is set to accept ssh version 2, I will issue the command ssh -l [username] -v 2 [remote switch ip address]
***Please rate and mark the comment correct if you find it helpful. Thanks.***
5 Replies 5
agapitca19
blankguy7,
The "connection refused" on the output could mean anything. Like command transport input ssh is probably not set on line vty and just telnet. It could also be the switch is configured for a specific ssh version and you need to specify that ssh version when trying to remote in to the switch.
Can you please provide the running configuration of the switch or the ssh AND line vty configuration?
Thanks.
This problem occurred suddenly. Before everything worked well...
Here's the ssh configuration:
#show run | inc ssh
ip ssh time-out 60
ip ssh version 2
privilege exec level 15 ssh
transport input ssh
transport input ssh
line vty 0 4
access-class 50 in
exec-timeout 15 0
transport input ssh
transport output none
line vty 5 15
access-class 50 in
exec-timeout 15 0
transport input ssh
ntp server 192.168.0.30
ntp server 192.168.0.221
end
But.... strange :
# show ssh
%No SSHv2 server connections running.
%No SSHv1 server connections running.
Best regards,
J.
ip ssh version 2
blankguy7
I've installed again and it is now running.
Thanks a lot and have a nice day ;)
Good to hear that the issue is resolved now.
