10G Port on WSA S695
Jay Tiwari
Hi Experts,
My customer got WSA S695 appliances and want to connect to 10G. In Datasheet and hardware guide I don't see P1 and P2 interfaces can be replaced with 10G port.
Ref: https://www.cisco.com/c/en/us/products/collateral/security/content-security-management-appliance/datasheet-c78-729630.html
https://www.cisco.com/c/en/us/td/docs/security/content_security/x95_series/hw/guide/wsa/install-wsa-x95/overview.html
Please let me know if we can put fiber SKU for 10G port to run P1 and P2 interfaces.
Jay
opryluts
Hi Jay,
You can but only in the case of S695F - https://www.cisco.com/c/en/us/td/docs/security/content_security/x95_series/hw/guide/wsa/install-wsa-x95/overview.html#id_84804
You want to check Figure 12 with a rear panel of S695F appliance.
Please vote for the response if you find it helpful.
MARK BAKER
Level 4
Level 4
My customer just ran into the same issue. WSA S695 was purchased, but now they want to connect to 10G. WSA S695F would have been the correct model to order. Is the official answer that you cannot upgrade the ports on the WSA S695 to 10G?
Hi @MARK BAKER,
Yes, you are right. If you haven't purchased it as S695F, you can't use 10G ports, as F model comes with 2x 10G SFP card.
BR,
Milos
you can not replace the model with 10G interface, it need to be order with 10GB interface.
BB
