Authentication Problems with IronPort S670, Windows 8.1, and IE 11
adam.miller
I can't explain why, but with the following configuration, authentication will not work:
Client is windows 8.1.
IE 10 or IE 11 auth won't work.
Weird thing is.. Windows 8.1 and Firefox works. So does Chrome. No problems at all.
Also, IE10 on Windows 8.0 works.
Anybody else experiencing this?
My setup:
IronPort S670
Windows Active Directory
WCCP redirection
donnylee
Adam,
Perhaps you could also share the access log from the S670 while testing with Widows8.1 and IE.
thanks,
-donny
priyanksharma
I think your traffic is matching with any identity on which you had defined MIME Type agent. Check your Global Identity and any custom policy with match-type of MIME agent. and  Yes Access log is needed while troubleshooting about this type of issues.
adam.miller
UPDATE:
This seems to have been fixed by updating windows. I'm sorry, I don't know which patch.
Miguel Morinigo
hi, due to a change with IE 11, the IE 11 user agent does not match any of the IE user agents that are predefined in the Identity. To match the user agent, please add the following string under the custom user agents field in the authentication Identity:
Trident
I had the same problem, was solved using that simple line.
miguel
