Block-AVC
icemoom
Visitor
Wondering if anyone can help, we have a website which is being blocked by our WSA reason Block-AVC, how can this be resolved? the page appears to be legit.
Ross
Ross,
Block-AVC is "Application Visibility and Control", so some where you have this configured to block this site/application.  Go to Web Security Manager / Access Policies, look in the "Applications" section...  (it may be a new app that an autoupdate picked up, and your default for that category of applications is set to block...)
Ken
JerryCrocker50583
Community Member
What you have to do is.  Turn on your phone's developer options settings. In developer options you will find what you were looking for. Scroll down the setting options and you will find AVC block list and it will allow you to enable or disable.
