Cisco WSA LDAPS intégration issue
ezzaariyouness
Hello everyone,
I'm trying to configure ldaps authentication On Cisco WSA, but I'm getting the issue attach
can you help me solve this issue.
19 Replies 19
Thanks for the tip
amojarra
Hi @ezzaariyouness
Maybe its best to take a look at : CSCvx42715 : Bug Search Tool (cisco.com) please and please verify your TLS versions.
Amirhossein Mojarrad
++++        If you find this answer helpful, please rate it as such      ++++
here is the TSL version on the wsa
amojarra
thank you @ezzaariyouness
I believe that would be best to take a PCAP and double confirm the connectivity and SSL handshakes.
you can put a filter for both your ADs divide them by "or" in the packet capture section, like :
host 1.1.1.1 or host 2.2.2.2
ezzaariyouness
this issue was related to this bug :  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwj13235
the workaround was to create a static route in Management for accessing AD and pointing to Data's Gateway .
Finally, I was able to integrate the WSA with LDAP Servers .
