Cisco WSA Migration from Hardware to virtual
We are using Cisco Secure Web Appliance (S690) as proxy servers(2 numbers) for Internet connection. Since the devices reaching EOS, we are planning to migrate it to VM.
Also at present the two appliances are in our DC and DR in standalone mode. After moving to VM, need to configure them in High availablility mode.
can anyone kindly help us out with specific recommendation and documents for above use case
amojarra
Hello @rameshkumarnakka
Hope you are doing well
There are a couple of items that I would like to share with you:
[1] For migration, there won't be any issue, you can import the configuration from S690 to your S600v, kindly be advised that Network Configuration, Joining the Domain(s), certificates, and licenses should be configured separately.
[2] Regarding the Virtual WSA, I would say it is best to take a look at these links before starting the deployment:
Ensure Proper Virtual WSA HA Group Functionality in a VMware Environment - Cisco
https://www.cisco.com/c/en/us/td/docs/security/wsa/wsa-va-install-guide/virtual-appliance-install-guide.html
[3] WSA, has high availability feature, which is Active/Passive. If you are looking for Active/Active (load balance) I would suggest:
Load balancing using WCCP or using a Network Load Balancer.
on the other hand (if you are using Explicit Deployment) you can have the load balance via PAC file or client's proxy configuration, by pointing some users to WSA-A and having WSA-B and secondary Proxy server and vise versa.
[4] you can find the steps, limitations and considerations in deploying High Availability in user-guide : User Guide for AsyncOS 15.0 for Cisco Secure Web Appliance - GD(General Deployment) - Connect, Install, and Configure [Cisco Secure Web Appliance] - Cisco
[5] In case if you are using Kerberos and planning to use Network Load balancer, kindly review "Creating an Active Directory Realm for Kerberos Authentication Scheme" section of the user-guide:
User Guide for AsyncOS 15.0 for Cisco Secure Web Appliance - GD(General Deployment) - Acquire End-User Credentials [Cisco Secure Web Appliance] - Cisco
Please feel free to let us know if there are any questions or concerns.
Amirhossein Mojarrad
++++     If you find this answer helpful, please rate it as such    ++++
amojarra
Hey @amojarra , thank you for above text but when i was uploading the configuration file showing error like p2 interface error at 32 line.
I've cross verified and find that 690 is having p1,p2 interfaces but coming to virtual version i can't able to see the P2 interfaces.
amojarra
Thank you so much for the update,
so for this issue:
[1] you can check the number of your NICs from VM level or from cli > etherconfig
Please be advised, if you are not using all 5 interfaces, your VM should have them all
[2] on the other hand, if you are getting an error related to P2 interface while importing the configuration, you can manually delete those tags from your configuration file ( if you are not going to use those interfaces )
as example if you would like to remove M2 interface please:
[2-1] Remove everything under <port_interface> tag
for example all of these Tags and sub tags:
<port_interface>
      <port_name>M2</port_name>
      <direct>
        <jack>M2</jack>
      </direct>
 </port_interface>
this is the physical definition of M2 interface
Note: that will be same for P2 or T1 .... if you dont have them, you can remove them
[2-2] and if there are any IP configured for that interface, and you dont need to import them to your virtual WSA, please remove everything inside <interface> tag related to that interface
for example remove all of these:
<interface>
      <interface_name>M2</interface_name>
      <ip>10.20.3.15</ip>
      <phys_interface>M2</phys_interface>
      <netmask>24</netmask>
      <interface_hostname>Amir-SWA</interface_hostname>
</interface>
This is layer 3 configuration of the M2 interface
[2-3] you might get another Error for the interface as well, which most probably you will, so plese remove everything under tag related to that interface as well
 <ethernet>
      <ethernet_interface>M2</ethernet_interface>
      <media>autoselect</media>
      <media_opt></media_opt>
      <macaddr>40:40:40:40:40:40</macaddr>
    </ethernet>
this is the layer 2 configuration of M2 interface
on the other hand, please feel free to open a TAC case, we will be more than glad to assist you
