Cisco WSA (SWA) Capabilities: Confirmation of Features.
MSN
Our customer is considering purchasing Cisco WSA, and they would like to confirm if the following requirements are feasible with the solution before proceeding. Could someone please provide a quick response to the inquiries below?
  1. Is it possible to configure Cisco WSA to:
    • Alert on access to suspicious, dangerous, or blacklisted websites?
    • Generate alerts for exceeding bandwidth usage?
  2. Can the proxy be configured to control and limit bandwidth usage for individual users or IP addresses?
  3. Does Cisco WSA include sandboxing features that allow for blocking specific hash values or files?
  4. Is it possible to integrate Cisco WSA with our existing SIEM and monitoring systems, such as SolarWinds?
Thank you in advance for your guidance!
balaji.bandi
check my short answers.
1. yes it will be generated logs, you can generate report, if you have central logging send the logs and do the alerts based on alerts required.
2. check control bandwidth options :
https://www.cisco.com/c/en/us/td/docs/security/wsa/wsa11-0/user_guide/b_WSA_UserGuide/b_WSA_UserGuide_chapter_010010.html
3. yes that is addon features you need to buy that.
guide lines :
https://www.cisco.com/c/en/us/support/docs/security/email-security-appliance/215165-best-practice-guide-for-advanced-malware.html
4. You can do export the logs to SIEM from WSA Logs
https://www.cisco.com/c/en/us/td/docs/security/wsa/wsa11-0/user_guide/b_WSA_UserGuide/b_WSA_UserGuide_chapter_010111.html
https://www.cisco.com/c/en/us/support/docs/security/web-security-appliance/118074-configure-wsa-00.html
BB
balaji.bandi
guide lines :
BB
