Creating a Certificate For C9300 Web Page
IES Sys Admin
Greetings!
I am trying to create and issue an certificate for my Cisco C9300s. When we access our secure webserver for the switch it says it is not secure. We connect with https://ipaddress. I am using this How To to get it to work. Issue is when I import the Web Server certificate from my CA for the switch and go to the webpage it still say the connection is insecure and the certificate isn't valid event though the Cert came from the CA.
ON the CN for the subject-name I can set the hostname or the IP. For the SAN I can't set the IP. I can only set a name.
I set the CN as the IP and that still doesn't say it is secure. What am I missing?
balaji.bandi
You can use wild card certificate, and make DNS Enry for that switch. Make sure your browser also have same certificate installed.
BB
Can you give me directions on doing that?
IES Sys Admin
I am going to lay out we do not use OpenSSL as we are not allowed to. WE have to use our on network CA. For the CN I have set the CN to the IP address of the certificate. For the SAN Cisco has a separate commands that says ip-address which adds the address and there I have a different command called subject-name-alternative of which I can't add an IP address to that command as it is not allowed. So what I find I can do the following:
CN can be the following:
  • IP address
  • Hostname
  • FQDN
SAN (Subject-Name-Alternative can be the following:
  • Hostname
  • FQDN
IP address can be added or not
Tried a mixture of all those things and it is still telling me the certificate is invalid on EDGE with the error: NET::ERR_CERT_COMMON_NAME_INVALID. If you look at the certificate from Edge it shows the same certificate if I open it on its own with the same fingerprints.
So what should the CN be when accessing it from the IP address using Edge?
IES Sys Admin
Also when doing the following to make the CSR I add the IP Address line. But when I look at the certificate it doesn't look like the IP address is added to the SAN. In fact the certificate does not have a SAN at all. It looks like something is getting lost in translation.
crypto pki trustpoint my-trustpoint
enrollment terminal pem
subject-name C=US, ST=Pennsylvania, L=My-Town, O=My-Org, OU=My-Department, CN=My-Switch.my-network.com
subject-alt-name my-switch.my-network.com
serial-number none
ip-address 192.168.1.51
revocation-check none
rsakeypair my-4096rsa-key
end
Any idea why it isn't including the IP address into the SAN?
