How ISE Availability Works
vrian_colaba
Need Help! We have two ISE server running on a VM and we wanted to change the core from 1 to 2.
Changing the number of core to 2 required shutting down the server.
  1. Shutdown the BRC ISE server (secondary)
  2. Change the number of core to 2
  3. Power on the BRC ISE server (secondary)
  4. Shutdown the RSV ISE server (primary)
  5. Change the number of core to 2
  6. Power on the RSV ISE server (primary)
Is the RSV ISE server after I shutdown and power back on will preempt its original role of Primary? Or should I manually make it as a Primary?
RSV and BRC is just the name of the DC.
Thank you.
vrian
5 Replies 5
balaji.bandi
how is this confiured ?
If they configured as Loadbalance, all your Service configured in the same Box like Mnt/PSN. it automatically detect and failure of the node and send the traffic to active one. once the secondary come back load share automatically. same situation on primary.
BB
Is there's a Preemption on ISE?
Thank You.
vrian
It all depends on the persona:
  • For monitoring the active role will switch automatically
  • For PSN, there is no primary/secondary as the load is shared by the NADs
  • For Admin, by default there is no change of the role. While the primary admin node is down, it is just not available. That is no problem for most of the functionality when it comes back shortly later.
But are you sure that even two cores are enough? Depending on the ISE version that is far less than needed for normal operation. And while being offline also adjust the RAM if needed.
vrian_colaba
So the current Primary ISE server will still be the Pimary?
Unless you have configured PAN failover which is not on by default. But with 1 Core, I assume that you run an ancient ISE-version that does not have that option.
