11-25-2018 09:52 PM
How to activate smart license in WSA?
looking for smart license installation procedure in WSA.
Solved! Go to Solution.
08-02-2019 10:10 AM
Hi All,
WSA Smart Licensing is available now. For more details please find the below link.
11-26-2018 06:11 AM
11-26-2018 07:41 AM
Thank you for your information. @Ken Stieers
08-02-2019 06:06 AM
Has this been released yet?
08-02-2019 06:11 AM
08-02-2019 06:20 AM
This post is the number one result when you search for "How to activate smart license in WSA" in Google. It would be helpful if it contained information or a link to an article on doing that.
08-02-2019 10:10 AM
Hi All,
08-02-2019 10:40 AM
Note that Smart Licensing must be enabled directly on the WSA and is enabled separately on the SMA that it is joined to. The documentation doesn't seem to mention that point. For someone acquainted with other Cisco products, but new to Ironport, this can be a challenge. Also, ESA requires version 12 for Smart Licensing, which hasn't been released at this time. Traditional ESA licenses on older versions must be applied from the CLI.
Not at all intuitive for a process that isn't performed regularly.
08-02-2019 10:44 AM
08-03-2019 04:39 AM
This is similar for WSA's. Please understand that if you move to smart licensing, you would no longer be able to switch it back to Manual licensing and You would need help from the licensing team.
Shikha Grover
PS: Please don't forget to rate and select as validated answer if this answered your question
