How to activate smart license in WSA
wahidengr
How to activate smart license in WSA?
looking for smart license installation procedure in WSA.
9 Replies 9
Smart licensing isn't released for WSA yet...it's coming in 11.7
That beta just finished, I'm not sure when FCS is scheduled.
Thank you for your information. @Ken Stieers
Has this been released yet?
Yes.
11.7 is out and 11.8 is in Limited Release
This post is the number one result when you search for "How to activate smart license in WSA" in Google. It would be helpful if it contained information or a link to an article on doing that.
Note that Smart Licensing must be enabled directly on the WSA and is enabled separately on the SMA that it is joined to. The documentation doesn't seem to mention that point. For someone acquainted with other Cisco products, but new to Ironport, this can be a challenge. Also, ESA requires version 12 for Smart Licensing, which hasn't been released at this time. Traditional ESA licenses on older versions must be applied from the CLI.
Not at all intuitive for a process that isn't performed regularly.
ESA 12 is released
ESA 12.5 is released
ESA 13.0 is in beta.
shgrover
https://www.cisco.com/c/en/us/support/docs/security/email-security-appliance/214614-smart-licensing-overview-and-best-practi.html
This is similar for WSA's. Please understand that if you move to smart licensing, you would no longer be able to switch it back to Manual licensing and You would need help from the licensing team.
Shikha Grover
PS: Please don't forget to rate and select as validated answer if this answered your question
