HOW TO Allow HTTPS through ASAv
Thien are Margo
Frequent Visitor
Frequent Visitor
Hi, i have topology and i want connect to google.com via browser (Https) . Although i can ping ICMP to google.com but my browser (Win7 VMware virtural machine) can't access. please help me !
ASA Version 9.9(2)
terminal width 511
hostname ASA1
domain-name thien.vn
enable password $sha512$5000$uDk98HhXLXO7G1C0xFYfjQ==$lZBdEx9gG70IhJ/aOWpBIw== pbkdf2
names
interface GigabitEthernet0/0
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
nameif DMZ
security-level 50
ip address 4.0.0.254 255.0.0.0
interface GigabitEthernet0/2
nameif inside
security-level 100
ip address 8.0.0.254 255.0.0.0
interface GigabitEthernet0/3
nameif outside
security-level 0
ip address 3.0.0.254 255.0.0.0
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
nameif inside1
security-level 100
ip address dhcp
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 192.168.27.2
name-server 8.8.8.8
object network OUT_REAL
host 3.0.0.2
object network DMZ
host 4.0.0.10
object network INSIDE
host 8.0.0.10
object network DMZ_REAL
host 4.0.0.1
object network OUT
host 3.0.0.10
object network INSIDE_REAL
host 8.0.0.1
access-list PING extended permit ip any any
access-list PING extended permit icmp any any
access-list PING extended permit tcp any any
access-list dmz extended permit ip any any
access-list dmz extended permit icmp any any
access-list dmz extended permit tcp any any
pager lines 23
mtu DMZ 1500
mtu inside 1500
mtu outside 1500
mtu inside1 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 8192
nat (outside,DMZ) source static OUT_REAL DMZ
nat (outside,inside) source static OUT_REAL INSIDE
nat (DMZ,outside) source static DMZ_REAL OUT
nat (inside,outside) source static INSIDE_REAL OUT
access-group dmz in interface DMZ
access-group PING in interface outside
route outside 0.0.0.0 0.0.0.0 3.0.0.2 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication login-history
http server enable
http 0.0.0.0 0.0.0.0 inside1
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
no validation-usage
crl configure
crypto ca trustpool policy
auto-import
telnet timeout 5
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 inside1
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
console serial
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
username thien password $sha512$5000$jHVviBsVGJrW/16aaGLmjg==$91jqJnATDbeT3o1fDGefRA== pbkdf2 privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect ip-options
inspect netbios
inspect rtsp
inspect sunrpc
inspect tftp
inspect xdmcp
inspect icmp
inspect icmp error
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect esmtp
inspect sqlnet
inspect sip
inspect skinny
policy-map type inspect dns migrated_dns_map_2
parameters
no tcp-inspection
policy-map type inspect dns migrated_dns_map_1
parameters
no tcp-inspection
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email [email protected]
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
profile License
Cryptochecksum:61e1e0d10f4e47892b05dbcbb6c8b0b6
: end
6 Replies 6
Thien are Margo
Frequent Visitor
Frequent Visitor
I am 4 year student, i am newbie
You need only dynamic NAT form DMZ to OUT
Also you need in user to specify DNS server 8.8.8.8
MHM
I have static NAT from DMZ to OUT and opposite. I use Dns name-server 192.168.27.2 ( this is wins server of adapter net8 have NAT in VMware) and it pull off. Now i can access to internet. But i have some new question under post. I hope you could read it.
Thank MHM
balaji.bandi
First of all why you need PC to in DMZ ? any reason ? Always user PC should be inside ?
Do you have any ACL in the DMZ Router mentioned in the diagram ?
i do not see any ACL (high level in your config)
check below configuration to help you :
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/118996-config-asa-00.html#anc7
BB
Sorry Balaji.Bandi, i forget show all my topology
So, you can see i want config PC in DMZ to server web local. it help client in LAN connect to DMZ website.
This topology is a graduation project applying network automation to system monitoring (ASA). But i don't have any idea. I want monitor packet http via Asa from PC in CLIENT. Do you think it possible?
Everything is possible in the technology, but doing right thing is always best practice.
But your Server in Inside, Generally we put services in DMZ for semi-trusted.
https://en.wikipedia.org/wiki/DMZ_(computing)
BB
