03-06-2020 02:24 AM
Hello Experts,
Currently, we have M670 Management appliance console with two WSA S680. As you are aware that M670 is EOL and EOS, so we need to upgrade it to M695.
Can we configure M695 Management with WSA S680, if yes, then shall we configure with the same OS version ?
Solved! Go to Solution.
03-06-2020 03:07 AM
yes you can manage the new Manangement with OLD WSA, subject to have right Async OS, i have done many implementation like this, i do not see any issue.
I am running some Management with Async OS - 11.5.1-115 ( stable) - 12.X available. but at this moment all good Live service point of view.
Bare in mind, you wont be able to ship the Logs archieve this is one of the pain i have encountered. Once you moved to new Manangmeent all Logs are gone, suggest to take backup as required if any compliance you looking.
03-06-2020 03:07 AM
03-06-2020 03:13 AM
Thank you for the quick response.
So you mean, the logs will be erased and the same Async OS can be work with New Management appliance.
Correct me if I am wrong.
03-06-2020 07:50 AM
yes you can not export Logs, That is what my experience.
yes you can manage WSA with compatable.
03-06-2020 04:26 PM
Thank you 😊
