Problems with SNI and SSL proxy
Erik Dahle
I'm currently testing SSL proxy on a S670.
This works fine with most domains, no warnings in the browser.
However, with certain google-domains it doesn't.
If I try https://www.gmail.com Chrome refuses to connect, and says "can not connect to the actual webpage www.gmail.com", and IE throws a certificate warning.
https://www.google.com works fine, without any warning.
Same with https://accounts.google.com, but when I try to log in, the request eventually times out:
URL: POST https://accounts.google.com/ServiceLoginAuth
Notification: GATEWAY_TIMEOUT
Anyone seeing anything similar to this?
Current AsyncOS Version: 8.0.6-078
Running in explicit mode, but have the same issues in transparent.
0 Replies 0
