"Update for raid controller firmware" in availabel system upgrade does not go away after upgrade
sokarlsson
Level 3
Level 3
We have two Ironport WSA, one S360 and one S370. Both stil have the "Update for raid controller firmware" still listed in "Available upgrades" even though we have done the update and rebooted the appliances.
How can we confirm that the update is applied?
If it is and the notice is still there how do we get rid of the reminder?
Go to the command line of the appliacne and run "version"
That will show you the current version of the firmware.
If you have record of what was there, you can compare...
Otherwise contact TAC, they can verify that you have the up-to-date version and pull your serial from the distribution list so you don't see it any more.
Ken
donnylee
The option to upgrade RAID firmware will remain there even you have performed the upgrade.
It will only disappear from the option when your serial number is removed from the provisioning list.
-donny
