scansafe on multi context ASA
johng231
Level 5
Level 5
Hello-
We are testing out in our LAB using Scansafe on a multi context ASA Firewall running version 9.1.(4). We are seeing an issue where the proxy servers become unreachable after a very short period of time, and stays in this state forever until you remove/reapply the config.
Is this a bug in the version we are running in the LAB? Also, I noticed when using multi context, you can't specify the FQDN for the proxy server in the system context, it has to be the IP address. Is there away of specifying the FQDN?
scansafe general-options
server primary ip 72.37.171.131 port 8080
server backup ip 80.254.156.99 port 8080
retry-count 5
context LAB
  member FW-LAB
  allocate-interface GigabitEthernet0/0.400
  allocate-interface GigabitEthernet0/0.444
  allocate-interface GigabitEthernet0/1
  allocate-interface Management0/0
  config-url disk0:/lab.cfg
  join-failover-group 1
  scansafe license xxxxxxxxxxxxxxxx
show scansafe server
Primary: 72.37.171.131 (UNREACHABLE) for last 1 day 21 hours, tried to connect 2337 times
Backup: 80.254.156.99 (UNREACHABLE) for last 1 day 21 hours, tried to connect 2916 times
Thanks in advance!
-John
Dhiren Tailor
With regards to the first question relating to a possible bug with the towers becoming unreachable, I recommend opening a case with TAC as soon as posssible providing a show tech-support output also for deeper analysis on the fault conditions and possible causes.
With regards to the FQDN the syntax would be the following in the system Context amending the "xxx" with your provisoned towers for the site you are configuring.
server primary fqdn proxyxxx.scansafe.net port 8080
server backup fqdn proxyxxx.scansafe.net port 8080
retry-count 5
license Ne.oPiqMN56V9eiW encrypted  < - Company Licence
All Sub-Context configs would use custom group licence that you created on the online portal.
An example of my test lab whcih is working can be seen below:
admin-context admin
context admin
  description asa_admin_context
  config-url disk0:/admin.cfg
  scansafe license < OMITTED >encrypted <- Custom Group Licence
context labtext
  description asa_dtlab_context
  allocate-interface GigabitEthernet0/2
  allocate-interface GigabitEthernet0/3
  config-url disk0:/dtlab.cfg
  scansafe license encrypted <- Custom Group Licence
