Separate default route for P1 and P2
poulid
Hi there. Is it possible to configure P1 and P2 on a Cisco WSA so that they each have their own default route?
amojarra
Hi @poulid
Having two default routes (0.0.0.0/0) for P1 and P2 is not possible, However you can configure static routes and define the gateway which is corresponding to P1 or P2.
for Example : 10.0.0.0/8 -> P1's gateway and 0.0.0.0/0 P2's gateway .
++++   If you find this answer helpful, please rate it as such  ++++
Amirhossein Mojarrad
amojarra
Hi @poulid
balaji.bandi
You have manually make static Routes.
BB
poulid
Dang. Ok, thx for the responses folks.
