- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-10-2015 09:26 AM
We are seeing throughput and CPU issues with our pair of S670 proxies.
Both S670s are running AsyncOS 7.7.0-761 and their overall CPU usage is around 20-30%, however the Web Proxy CPU usage is showing 100% during the day and around 40% after hours when most people are no longer in the office.
Here is a "status" snapshot for a typical day.
Enter "status detail" for more information.
Status as of: Tue Feb 10 11:17:01 2015 CST
Up since: Thu Dec 11 22:12:41 2014 CST (60d 13h 4m 19s)
System Resource Utilization:
CPU 21.8%
RAM 0.0%
Reporting/Logging Disk 24.0%
Transactions per Second:
Average in last minute 844
Bandwidth (Mbps):
Average in last minute 86.489
Response Time (ms):
Average in last minute 296
Connections:
Total connections 16055
However here is the proxystat output from the same time period.
Press Ctrl-C to stop.
%proxy reqs client server %bw disk disk
CPU /sec hits blocks misses kb/sec kb/sec saved wrs rds
98.00 608 611 2532 2944 66128 57309 13.3 2210 544
98.00 676 498 2617 3645 95540 89996 5.8 2911 567
99.00 777 770 3038 3960 89891 76332 15.1 2948 1093
98.00 710 555 2988 3548 83362 78107 6.3 2567 595
99.00 696 871 2516 3588 81584 71525 12.3 2634 875
99.00 731 850 2958 3500 96219 83045 13.7 2197 917
98.00 700 586 3106 3318 72434 61207 15.5 2024 478
99.00 786 852 3236 3793 107520 93851 12.7 2228 1083
We are trying to figure out what exactly is causing the high CPU usage, but everything in terms of the content being served seems normal.
Our Internet connection is 500 Mbps and between the two S670s we are only able to hit around 300 Mbps.
Solved! Go to Solution.
- Labels:
Web Security
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2015 01:17 PM
Get off of 7.7 as soon as you can...
Seriously. There were performance issues... they fixed a bunch of them in 8.0...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2015 01:17 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-19-2015 07:18 PM
There are multiple factors that can contribute to high usage of proxy CPU.
From the 'rate' output provided, the requests per seconds are quite high as well and if the configuration in the appliance is very expensive, this will definitely causing proxy CPU to be very high.
Configuration been expensive if you have more than 25 on each Identities, Access Policies and Custom URL categories and regular expression(this part is the most resource intensive).
Since the way the appliance work, it will check every single traffics that come to the appliance from top to buttom for each Identities, Access Polcies, etc until the condition is met and if you have massive requests/traffics at the same time or per seconds and the appliance need to perform this for every single requests/traffics, it will then use up all the resources that it has and the CPU tend to be spiking.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2015 08:03 AM
Upgraded to 8.0.6 and the CPU issues went away.
The proxy CPU time went from 100% down to 55%.
