WSA Hard Drive Status
broadleon
We have been having an issue with the S170, the hard drive indicator has been flash green/orange for over 24 hours. We assumed it was a raid rebuild, but not so sure now due to the time length.
Has anyone else had this issue ?
I have, though not on a WSA. I've had rebuilds fail when the drive had an intermittent problem.
Open a case and have TAC access the box from their side.  They can see if the rebuild is still in process or has failed and dispatch a drive if needed.
Sriram Subramanian
Green/Orange flashes would mean the hard drive is operating normally. You can monitor the RAID status from the CLI using the version command.
You can find more information related to replacing the failed drive here:
http://www.cisco.com/c/en/us/support/docs/security/email-security-appliance/118568-technote-esa-00.html
