WSAv in explicit mode and IP Spoofing (no WCCP)
When we use the IP Spoofing functionality in explicit mode with an IP address not being the client address, but from some other range.
And of course routing that address back to the WSAv and we don't use a WCCP router.
Do we need to configure that ip address somewhere in the interfaces? Or is that automagically done when ip spoofing is enabled?
Ok now i understand your requirement :
check below guide how this can be done :
https://www.youtube.com/watch?v=LDVW9uFdj7s
BB
6 Replies 6
balaji.bandi
when you configure explicit mode you only see WSA IP address not client IP address.
you like to forwardf client IP - X-Forwarded-For
UI, Security Services -> Web Proxy -> generate headers-> x-forwarded for   - this should be set to "send".
BB
That is not what I want to achieve. I want to use a different IP address so that a traffic shaper can recognize this traffic and assign a specific shaping profile to this traffic.
I want to use a different IP address  - explain more
WSA have P1 and P2 interface - One inside and One outside, when the connection going out it used WSA outside interface IP and request the content ? what you trying to do here ?
BB
What I'm trying to achieve here is that traffic from a specific set of clients, going through the proxy and to a specified number of destinations (hostnames) is limited in the bandwidth they can consume.
Bandwidth limitations in our setup is done by a traffic shaper just before the internet connection. They can apply a different shaping class based on source ip or destination ip. The destination ip's changes too much and is not under our control, therefore I try to have a solution based on source IP.
So want I want to do is:
  • create an identification profile using the client ip addresses and a custom URL category matching to concerned hostnames.
  • create an IP Spoofing profile in which I use a new ip address.
  • create a Routing Policy using the above created identification profile and IP Spoofing profile.
  • configure the routing such that the configured spoofed address is routed to the WSAv
  • In our setup we have 4 active WSAv's which are loadbalanced by a Radware loadbalancer. Traffic from the clients can reach any of those 4 WSAv's.
  • We have a SMA for defining the global setup (Routing policy & Identification Profile), each WSAv has its own IP Spoofing profile (sharing the same name on all WSA's).
BB
Thanks for sharing the link to the guide. That will help.
Henk
