can i enable the SSO withou ADFS
o.aljaberi
Hi Team ,
there is a way to enable the SSO if we don't have ADFS
Vaijanath Sonvane
For SSO and Control Hub, IdPs must conform to the SAML 2.0 specification and must be configured in certain manner. Please see below document for more details:
https://help.webex.com/en-us/article/lfu88u/Single-Sign-On-Integration-in-Control-Hub
If you have your own identity provider (IdP) in your organization, you can integrate the SAML IdP with your organization in Control Hub for single sign-on (SSO). Cisco has tested following IdPs:
  1. Active Directory Federation Services (ADFS)
  2. Duo
  3. F5 Big-IP
  4. Google Apps
  5. Microsoft Azure
  6. OKTA
  7. PingFederate
  8. Shibboleth
  9. SimpleSAML
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
