Cisco IOS XE software vulnerability
yashasvi kesamreddy
Community Member
Hi Team,
Can you please check for this Cisco IOS XE software (CVE-2023-20198 is a privilege escalation vulnerability affecting Cisco IOS XE software), receiving the highest possible CVSS score of 10?
Is this affecting our Cisco devices or not?
If yes, please share the process to remediate this vulnerability.
yashasvi kesamreddy
Community Member
We are not sure about this.
Can you please elaborate more on this information.
Hello @yashasvi kesamreddy,
as the security advisory states all devices running IOS-XE (e.g. switches, routers, access points, etc.) are affected, if the HTTP/HTTPS web server is enabled.
Here is a list of devices which use IOS-XE:
Cisco IOS XE - Cisco
In order to be vulnerable, the following commands (or either one of them) must be present in the configuration:
ip http server
ip http secure-server
As the security advisory implies the vulnerability can be mitigated by disabling this feature (no ip http server / no ip http secure-server), if it is not required. If it is required, then you should block the web access to the vulnerable devices from untrusted networks.
Best regards
Igor
balaji.bandi
check below effected devices :
https://sec.cloudapps.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-iosxe-webui-privesc-j22SaA4z
BB
