Cisco Room Kit Integration with MS Teams
Nishant Patil
I'm not able to join the meeting of Teams on Cisco Room Kit.
I have enable all the options which are there on Device Configuration as well WebRTC is also Enable, Macros is also being added, Anything more I need to config??
Nishant Patil
I have not used the PowerShell command..
Work with the M365 admin to complete that step. And if you haven't already, you'll need to setup Hybrid Calendar so Webex can read the invites and send One Button to Push (OBTP) details to the endpoint.
Jonathan Schulenberg
Have you used the PowerShell command on the room resource mailbox?
Set-CalendarProcessing -identity "room" -DeleteComments $false
 The default MSFT config clears the body of a meeting invite once it’s accepted by the room; the endpoint can’t join without the URL.
