Cisco Webex Boarrd 70s - external microphones
LP14
Hi all and thank you in advance for your attention.
I would like to know if there is a way to add some external microphones to the board to amplify the volume in. If yes how can I do that ?
really thank you
best regards
Ashish Patel
Hi. No sorry Webex Boards before the Webex Board Pro (latest) models do not support external microphones.
The microphones in the S model are built in and at the top of the board approx 12 of them.
Also not sure which OS version you are on whether you can turn off some of the noise cancellation and see if you get better coverage.
ashish
Response Signature
Ashish Patel
ashish
Response Signature
